max psi
Old Nov 8, 2006 | 04:26 PM
mugenDA9 lover's Avatar
Default max psi
i have a bone stock b16a block (OBD0) with port and polished head and 3 angle valve job. im going turbo and have everything i need and i am running a t3/t4 to4e turbo. i have a 255lph pump and rc 550cc injectors. my question is what is a safe boost psi for a daily driver with a very good tune with my stock bottom end? thanks guys
Old Nov 8, 2006 | 04:37 PM
NJIN BUILDR's Avatar
Default Re: max psi (mugenDA9 lover)
Safe is a bad word.There are lots of b16's running 10-12#'s with real engine management."Safe" for a stock b16 dd is probably 6-8#'s.
Old Nov 8, 2006 | 04:43 PM
shortyz21's Avatar
Default Re: max psi (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Safe is a bad word.There are lots of b16's running 10-12#'s with real engine management."Safe" for a stock b16 dd is probably 6-8#'s.</TD></TR></TABLE>
6-8 on a stock block well tuned is safe? ur living in the stone age pal
id say 12 daily. and like 15 at the track is fine..
Old Nov 8, 2006 | 04:57 PM
Default Re: max psi (shortyz21)
well i was hoping to run 10psi and i def have a guy that can tune. what do you recomend for fuel management?
Old Nov 8, 2006 | 05:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">
id say 12 daily. and like 15 at the track is fine.. </TD></TR></TABLE>
Like I said ,safe is a bad word.
Old Nov 9, 2006 | 12:33 PM
b18sihatch's Avatar
10psi imo would be a safe range to shoot for
Old Nov 9, 2006 | 12:41 PM
adseguy's Avatar
Like I said ,safe is a bad word.</TD></TR></TABLE>
more like PSI is a bad word. Use horsepower to determine the safety PSI has NOTHING to do with "safety".
To the OP 300whp seems to be the norm. For B16's because of the low torque we see lots of 330whp and up cars doing just fine.
Old Nov 9, 2006 | 06:03 PM
Default Re: max psi (adseguy)
so your saying that as long as i stay around 300 i should be ok? since this is my dd i wanna make sure it will last for at least a year because that is when i plan a full motor build. but i also wanna have something fast and fun until then
Old Nov 9, 2006 | 06:11 PM
blackeg's Avatar
run enough psi to make at or a little under 300 whp. now...depending on the setup, that probably 8-11 psi. you cant really run over 10.7 psi on a stock map sensor anyhow
Old Nov 9, 2006 | 06:57 PM
lakai_19's Avatar
11.7 is stock maps sencers limit
Old Nov 9, 2006 | 07:36 PM
ProjectDarkBlack's Avatar
Default Re: (lakai_19)
get a B18A and you can replace the block like it is a paper plate
then get it up to 350whp as long as you can (you would be very suprised)
97grnrs
Jan 6, 2008 07:07 PM
DVPTeG
May 22, 2007 08:34 PM
Boosted B6teen
11
Dec 6, 2005 04:31 PM
crazyimport
Aug 24, 2004 04:26 PM
mrx
Jul 29, 2004 11:02 AM
