Compression
Old Nov 11, 2006 | 02:18 PM
jrockets's Avatar
Default Compression
Hello, I recently did a compression test on my lsvtec and it came out @ 150 on all four cylinders. Just wondering if this sound right since i have low compression pistons. Here is my setup,
GSR port n polish head
Skunk 2 springs and retainers
GSR cams
GSR valves
Venom Intake Manifold
BBK 70mm throttle body
hondata intake manifold gasket
STR fuel rail
APR head studs
Aeromotive fpr
walbro pump
98 b18b LS block (legit paperwork)
stock sleeves
JE 9:1 pistons
Eagle rods
block gaurd
S200 on a P28
Old Nov 11, 2006 | 02:21 PM
beepy's Avatar
Default Re: Compression (jrockets)
If it's the same on all 4 you are fine.
What compression you get on the test is as much a function of the camshaft as it is the static compression ratio.
Old Nov 12, 2006 | 11:46 AM
jrockets's Avatar
Default Re: Compression (beepy)
thanks, anymore inputs???
Old Nov 12, 2006 | 12:49 PM
quik sol's Avatar
good to go ...as long as there within 10 points of each other, and isn't way way low...your good
Old Nov 12, 2006 | 03:46 PM
00Red_SiR's Avatar
All Motor Mentor
Did you remember to disable the fuel system before you did the test?
99em1civicsi
Engine Machining & Assembly
40
May 28, 2016 09:49 AM
yolk
Jun 18, 2010 06:05 AM
Boosted_B_Series
Feb 13, 2009 07:45 AM
baynedo
Oct 11, 2006 05:35 PM
