Quick catchcan question
Old Nov 12, 2006 | 08:56 AM
dizzyek's Avatar
Default Quick catchcan question
ok I have my setup as follows. One line from the valve cover to the jaz catch can and one line from the black box to the catch can.
Now for the black box I pulled out the vacuum hose that goes into the box and shoved in another line. I wrapped the line in ducttape and put some silicone around it so it would fit snug in the hole.
Is this a good effective way to attach a hose to the black box? If not how did you guys do it . Its a really tight space back there and this is the only way I could get a line from the black box.
Thanks
Old Nov 12, 2006 | 03:55 PM
dizzyek's Avatar
anyone?
Old Nov 12, 2006 | 04:57 PM
platinum00's Avatar
Default Re: Quick catchcan question (dizzyek)
you can remove the block box an put a plug fitting in there. I just welded a AN fitting on the black box and ran my lines that way
platinum.
Old Nov 12, 2006 | 05:00 PM
dizzyek's Avatar
will it work like how i have it?
Old Nov 16, 2006 | 03:49 PM
platinum00's Avatar
Default Re: (dizzyek)
Yea it will work, but duck tape and silicone is not the best solution.
Remember oil likes to break down adhesives over time, so I don’t know how long it will last.
Why not just get the correct plug. It's only line 10 bucks or something.
platinum.
Old Nov 16, 2006 | 04:38 PM
coneheadsracing's Avatar
Default Re: (platinum00)
What size is the hole, if its the same as the other one your running, you should be able to use a pcv fitting. There are some that are hollow the whole way, and if you can't find one of those, just drill yours out.
wtsapexipowerfc
Nov 18, 2010 09:47 AM
Kr4nG
Apr 7, 2009 05:27 PM
sohcvtec91hatch
May 23, 2007 09:11 PM
Art701
15
Oct 25, 2004 06:25 PM
Art701
Oct 22, 2004 05:24 PM
