Low Idle problems
Old Nov 9, 2006 | 12:44 PM
brad98_teg's Avatar
Default Low Idle problems
When I start up my car It will idle right when cold. As soon as I get warmed up my idle will drop from 1000rpm to around 500 to 400rpm. The weird part is that while I'm cruising and I put it into neutral it will idle just as I set it, but when I come to a stop it will drop back down to around 500rpm. I checked for vacuum leaks but found none.Could I have fouled a plug while tuning that could cause this low idle?
thanks
Old Nov 9, 2006 | 01:52 PM
KLeSe's Avatar
Default Re: Low Idle problems (brad98_teg)
bump, I too would like to know
Old Nov 9, 2006 | 02:47 PM
brad98_teg's Avatar
bump
Old Nov 9, 2006 | 05:49 PM
brad98_teg's Avatar
bizump
Old Nov 9, 2006 | 06:55 PM
urnotfast's Avatar
Default Re: (brad98_teg)
bump......i have the same prob
Old Nov 9, 2006 | 09:03 PM
rdtech's Avatar
Default Re: (urnotfast)
get it tuned. Alot of electronic parts fluctuate its value over time.
tuning usually helps. Set the target idle to a higher value
Old Nov 10, 2006 | 01:30 PM
KLeSe's Avatar
Default Re: (rdtech)
If the car is stock, what needs to be tuned? Can you adjust the idle from the throttle body ? (done it on Crx)
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
ex94vtec
14
May 6, 2006 02:07 AM
DC2*Integra
Sep 20, 2005 12:51 PM
uneekcrx
May 17, 2002 06:45 PM
