Bigger Injectors?
Old Nov 10, 2006 | 04:24 PM
95dc2teg's Avatar
Default Bigger Injectors?
My current setup is t3/t4 57trim with .50a/r compressor side and .63a/r exhaust side. Tial 38mm wastegate set at 7psi, DSM 440s, Rev hard log manifold with dp. hks knock off bov, and ebay intercooler, all tuned with crome pro.
In the new year i wanna bump it up to 10 psi, i know im going to need to get walbro 255 and a retune, but my question is will my DSM 440's be maxed out? and would i need to get bigger ones to go to 10psi? im aiming for around 300 whp. Thanks.
Old Nov 10, 2006 | 05:13 PM
qfast817's Avatar
Default Re: Bigger Injectors? (95dc2teg)
i would get some 550's or if you plain to go bigger later on get some 780-880s
Old Nov 10, 2006 | 05:14 PM
sleeprhatch's Avatar
750's
Old Nov 10, 2006 | 09:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
i dont think 440s will do it, plus you need a resistor box for them, may i suggest saturated 550's? or dare i say 650's? they leave you room to grow into.
Old Nov 11, 2006 | 07:55 AM
Topdawgg's Avatar
just spend the extra money and go with 750s..
Old Nov 11, 2006 | 08:39 AM
b18sihatch's Avatar
750s
Old Nov 11, 2006 | 10:21 AM
95dc2teg's Avatar
Default Re: Bigger Injectors? (b18sihatch)
750's it is then, thanks guys
Old Nov 11, 2006 | 01:25 PM
Mr. Badwrench
750's will give you lotsa room and they are still saturated and dont need a resistor box.
Old Nov 11, 2006 | 02:20 PM
95dc2teg's Avatar
Default Re: Bigger Injectors? (boostedcivicsir)
but since i already have a resistor box wired in should i just get peak/hold 750's?
Old Nov 11, 2006 | 02:45 PM
Mr. Badwrench
if thats the case yes. but i think if you are running an obd1 ecu, i would use saturated injectors. but thats just me.
Old Nov 11, 2006 | 03:19 PM
95dc2teg's Avatar
what would the difference be? just wondering?
Old Nov 11, 2006 | 03:25 PM
Mr. Badwrench
this is my personal oppinon and i have heard from people, but have no hard cold facts to back it up, but i have seen in our tuning that an obd1 ecu with saturated injectors idle a little better generally run a little better than an obd1 ecu with p&h's with a resistor box. i myself have a resistor box, but also i am running 1200 cc/min injectors. they dont make sats over 750 that i know of.
IF I AM WRONG PLEASE CORRECT ME>
thank you that is all.
Old Nov 11, 2006 | 04:01 PM
95dc2teg's Avatar
does anyone else have anymore opinions on this? just trying to get more info. thanks!
jdmboy94
Oct 13, 2010 02:43 PM
jdmray
Oct 23, 2007 06:18 PM
JDM_EH2
Jun 27, 2005 05:57 PM
vtec-adykt
Feb 22, 2005 01:14 PM
sivik2nr
Jun 11, 2003 09:59 PM
