Best A/R ??
Old Nov 11, 2006 | 06:54 AM
harhoosh's Avatar
Default Best A/R ??
Its race car only and i am going to use race gas also.
my setup:
B20b
CP pistons 9.7 cr
eagle rod
GE guard
b16a head P&P
supertech valve spring
oem retainer and valve
b16 cams (or Blox B)
P30 intake
h23a vtec TB (64mm)
OBD 0 ecu with Bre (tuned by me)
GM 3 bar or Motorolla 2.5 bar map sensor
880 cc P&H injectors
Bosh Pump
B&M FBR at 50 psi
I am thinking of: T3/60-1 or T4/60-1
so, what you recomanded guys?
If its T3, What A/R? 0.63 or 0.82 ?
Or, if its T4, 0.58 or 0.62?
Thanks guys.
Old Nov 11, 2006 | 06:58 AM
quicksilver1689's Avatar
i ♥ snails
I think a t4 is a little too big for what you want to do. A t3 can take you where you want to go in terms with power for your build.
Old Nov 11, 2006 | 08:57 AM
h22 civic's Avatar
Default Re: (quicksilver1689)
82 on t3 62 on t4
Old Nov 11, 2006 | 09:29 AM
hoya_10fintec's Avatar
Default Re: Best A/R ?? (harhoosh)
I have a bone stock B20/VTEC with a T3/60-1... it's almost perfect for what I wanted..
not too laggy either.. it starts spooling around 4500 rpm~ish and when it starts going, it goes.. I just gotta get some better tires since I have no traction at all in 2nd gear.
My car ran 12.9 @ 1/4 mile(rough tune with Crome) on 7psi...
2.2 sec. 60' time and 114mph trap speed. And hopefully get it down to low 12's next year or boost it up a little more with better tuning and hit high 11's.
you'll like the T3 60-1(.82 A/R) A LOT...
good luck with your project.
oh, it helps to have LSD also... I personally think an LSD is a MUST.
Old Nov 12, 2006 | 04:34 AM
harhoosh's Avatar
Default Re: Best A/R ?? (hoya_10fintec)
thnks guys for replays.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoya_10fintec &raquo;</TD></TR><TR><TD CLASS="quote">you'll like the T3 60-1(.82 A/R) A LOT... </TD></TR></TABLE>
This what i will go with
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoya_10fintec &raquo;</TD></TR><TR><TD CLASS="quote">good luck with your project.</TD></TR></TABLE>
Thanks, i alredy ran 11.44 @ 119 mph last week with bone stock b20/vtec + 120 shot nos.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoya_10fintec &raquo;</TD></TR><TR><TD CLASS="quote">oh, it helps to have LSD also... I personally think an LSD is a MUST.</TD></TR></TABLE>
I have it already, my trans is Y1 with oem LSD.
Old Nov 12, 2006 | 07:35 AM
good.. you're already almost there!!
Mugencrxsir1
Feb 26, 2006 04:17 PM
joepiscapo_83
Jan 22, 2005 08:45 AM
f1 vtec
Jan 20, 2005 06:26 PM
DUCK COMMANDER
Oct 3, 2002 05:58 AM
