timing with TILTON clutch
Old Nov 8, 2006 | 01:44 PM
hyabusa hunter's Avatar
Default timing with TILTON clutch
hello everyone, i have a problem on my hands,
i have installed a tirlon twin disc clutch.... BUT.... i cant seem to time the motor, all you H22 fans know that you have to pull the bung on the gearbox housing to see the flywheel, well the tilton flywheel sits way far back and you cant really see it, o know there are timing marks on it cause i saw them when i looked at the flywheel! so HELP!!!!!!
Old Nov 8, 2006 | 01:59 PM
Turbogixxer's Avatar
Default Re: timing with TILTON clutch (hyabusa hunter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyabusa hunter &raquo;</TD></TR><TR><TD CLASS="quote">hello everyone, i have a problem on my hands,
i have installed a tirlon twin disc clutch.... BUT.... i cant seem to time the motor, all you H22 fans know that you have to pull the bung on the gearbox housing to see the flywheel, well the tilton flywheel sits way far back and you cant really see it, o know there are timing marks on it cause i saw them when i looked at the flywheel! so HELP!!!!!! </TD></TR></TABLE>
Mark the crank pulley at TDC on compression stroke #1 cylinder. Then mark the timing belt cover so it lines up with the mark you made on the pulley.
Then use a adjustable timing gun.
Old Nov 8, 2006 | 02:01 PM
Default Re: timing with TILTON clutch (Turbogixxer)
CAN EXPLAIN A BIT MORE? i have a snap on timing gun so how ?
Old Nov 8, 2006 | 02:14 PM
dmotoguy's Avatar
if you need more explanation maybe you should take it to somebody that knows what they are doing
Old Nov 8, 2006 | 02:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyabusa hunter &raquo;</TD></TR><TR><TD CLASS="quote">CAN EXPLAIN A BIT MORE? </TD></TR></TABLE>
Line up the timing belt like so:
put the lower timing cover and crank pulley on. Draw a line from the crank pulley (white out works good) to the timing cover. That is your new timing mark.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyabusa hunter &raquo;</TD></TR><TR><TD CLASS="quote"> have a snap on timing gun so how ? </TD></TR></TABLE>
They have a adjustable and non-adjustable. Adjustable means you can change the timing degrees with a **** or button(s).
Old Nov 8, 2006 | 04:15 PM
Muckman's Avatar
Moderator in Chief
I love Preludes. You cant even adjust the distributor either. It actually says to replace the ECU in the Honda service manual if the timing is off. lol
Old Nov 10, 2006 | 08:42 AM
so time it like a b series?
Old Dec 31, 2006 | 08:48 AM
just to let people know i timed the motor with the marks on my cam gears, it worked alot easier than marking the crank pulley...
thanks to all those who gave advice
Old Dec 31, 2006 | 09:28 AM
Bigblockhatch's Avatar
So how did u do that..............I really dont think that will work
Old Dec 31, 2006 | 03:39 PM
JDogg's Avatar
Default Re: timing with TILTON clutch (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">I love Preludes. You cant even adjust the distributor either. It actually says to replace the ECU in the Honda service manual if the timing is off. lol</TD></TR></TABLE>
thats b/c the crank pickup isnt inside the distributor, its on the end of the crank.
you can use the marks on the cam gears, get a dial back light, set it to what your computer says for timing and the 2 lines should match up perfectly.
Old Jan 1, 2007 | 01:44 AM
Default Re: timing with TILTON clutch (JDogg)
spot on! im running AEM ems, so i set my timing on 15 degree's, got the timing guy out, must be ajustable. sync both AEM and the timing gun readings....... Job done! Never actually had to move the dizzy at all! just tell the aem what timing the motor is at
Old Jan 1, 2007 | 08:46 AM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
the only problem you are gonna have with marking just a white mark is the timing is not set @TDC(white mark it is set @BTDC red mark.
Old Jan 1, 2007 | 02:16 PM
Default Re: timing with TILTON clutch (gunslinger)
no, i set the motor at TDC on cyclinder 1 first, checked it with the oil pump gear mark (behind the crank pulley) then i marked the cam gears up.
does this make more sense? or have i done it wrong then?
Old Jan 3, 2007 | 03:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunslinger &raquo;</TD></TR><TR><TD CLASS="quote">the only problem you are gonna have with marking just a white mark is the timing is not set @TDC(white mark it is set @BTDC red mark.</TD></TR></TABLE>
is this right then? am i wrong? is my timing out then?
Old Jan 3, 2007 | 04:18 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyabusa hunter &raquo;</TD></TR><TR><TD CLASS="quote">so time it like a b series? </TD></TR></TABLE>
*backhand*
just cut the valve cover and use the TDC mark.
set your timing gun (hopefully it's adjustable aka 'dial-back') to the timing you want and aim the gun at the cam gears.
this is what I do because the manifold I built blocks the timing hole.
Old Jan 3, 2007 | 04:23 AM
Default Re: timing with TILTON clutch (2point2)
thats what i have done, so am i ok then? i set the gun at 15 and the aem at 15 and sync'ed the both of them.......!
Old Jan 3, 2007 | 04:25 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyabusa hunter &raquo;</TD></TR><TR><TD CLASS="quote">thats what i have done, so am i ok then? i set the gun at 15 and the aem at 15 and sync'ed the both of them.......!</TD></TR></TABLE>
you're done.
now go hunt a hyabusa.
Old Jan 3, 2007 | 04:28 AM
sweet!!!! on my way!
gooberwolf
Aug 27, 2013 08:59 PM
hyabusa hunter
Nov 10, 2006 09:36 AM
mayhemdestroy
Aug 23, 2005 06:20 PM
BoostedH23a1
Dec 15, 2003 01:48 PM
papa_smurf
May 23, 2003 05:00 AM
