Ls/Vtec piston question....
Old Nov 8, 2006 | 07:26 PM
nebulight's Avatar
Default Ls/Vtec piston question....
Okay, I'm apologizing right now because I'm sure this has been covered before, but my searches came up empty.
I just picked up a B18C5 block and after reading about the C5 crank, it's heavier than both the LS and the GSR block, so I'm ditching that in favor of an LS crank. (I know the differences between the cranks and revs and all that) I know I have to use LS rods, but what pistons do I have to use:
B18C5 block : LS Crank : Ls Rods : ??? Pistons
Old Nov 9, 2006 | 02:45 AM
DaveF's Avatar
Default Re: Ls/Vtec piston question.... (nebulight)
i use b series vtec pistons, because of the larger valve relif.
Old Nov 9, 2006 | 06:36 AM
TheShodan's Avatar
Moderator
You'll enjoy the additional 25ft/lbs or so of torque from the LS crank than anything else. The Type R, and GS-R crank weight differences are negligible in a rotating assembly that is turbocharged. In these applications, that is the only difference
Old Nov 9, 2006 | 06:41 AM
nebulight's Avatar
Default Re: Ls/Vtec piston question.... (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">You'll enjoy the additional 25ft/lbs or so of torque from the LS crank than anything else. The Type R, and GS-R crank weight differences are negligible in a rotating assembly that is turbocharged. In these applications, that is the only difference</TD></TR></TABLE>
Right. So just to be sure, I can use any aftermarket B16/B18C pistons?
Old Nov 9, 2006 | 07:09 AM
eg crunkmonster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nebulight &raquo;</TD></TR><TR><TD CLASS="quote">Right. So just to be sure, I can use any aftermarket B16/B18C pistons?</TD></TR></TABLE>
pretty much but to get the right compression ratio, u have to order the right lsvtec pistons, earl took care of that for me when i ordered my cp's
Old Nov 9, 2006 | 07:31 AM
nebulight's Avatar
Default Re: Ls/Vtec piston question.... (eg crunkmonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg crunkmonster &raquo;</TD></TR><TR><TD CLASS="quote">
pretty much but to get the right compression ratio, u have to order the right lsvtec pistons, earl took care of that for me when i ordered my cp's</TD></TR></TABLE>
Nice, I'll be sending my block to earl for the sleeves anyway, so might as well get the pistons from him
Old Nov 9, 2006 | 07:49 AM
B18C1CYA's Avatar
you buy the pistons for what head you are running , sence they have diffrent chamber sizes , but Earl will ask you that any way
jamescb77
Mar 1, 2007 07:45 AM
civic_jdm16
Jan 19, 2007 06:11 AM
Shiro Z31-T
Feb 12, 2005 02:46 PM
B18PoweredCivic
28
Jun 10, 2004 04:08 PM
decypha
Feb 14, 2003 09:13 PM
