ZC DOHC Head Gasket
Old 11-13-2006, 11:54 PM
Wheelman-CZ's Avatar
Default ZC DOHC Head Gasket
Hello!
I am looking for some metal head gasket for my DOHC ZC engine. There is a firm which make some customs gasket so I want to ask them if they can do it.
But I need to know how thick it should be and is there anybody who has some drawing of it?
The stock compresion of this engine is 9,5 and I am going to use some vitara pistons.
Thank you!
Old 11-14-2006, 10:05 AM
fjt
fjt's Avatar
any d16 HG will fit.. My friend has a DOHC ZC with vitaras and he uses a D15 Head Gasket.
you just need to get a thin one to bump up the CR a lil cause the CR with Vitaras will be low on the DOHC ZC, unless you have a milled head or block.
Old 11-15-2006, 04:41 AM
Autoworks's Avatar
Default Re: ZC DOHC Head Gasket (Wheelman-CZ)
What you need to get is the HKS metal beaded head gasket for the 89 Integra D16A1. Just any SOHC headgasket does NOT fit properly, the correct gasket is for the D16A1 if you are just trying to trace one out for someone to make, not an SOHC civic gasket.
Also, I would advise against Vitaras in a DOHC ZC, it will drop your CR entirely too low, down to the 7s. The car would be a pre-boost slug.
boosted 95 coupe
06-12-2007 10:07 AM
Efbluevtec
05-28-2007 06:22 PM
blackEF
10-30-2002 04:33 AM
brent_G
10-11-2002 11:03 PM
Quick Reply: ZC DOHC Head Gasket
