When does the walbro struggle
Old Nov 14, 2006 | 10:41 AM
Quickgti1.8t's Avatar
Default When does the walbro struggle
Just wondering im running 750cc injectors at 3 bar, i have a walbro 255 hp, Im planning on running 25 psi. Can the walbro handle it or so i add a bosch 044 inline
Old Nov 14, 2006 | 02:35 PM
PrecisionH23a's Avatar
Default Re: When does the walbro struggle (Quickgti1.8t)
Your injectors will be the limiting factor.
The walbro has made a tad bit over 600whp safely.
Old Nov 14, 2006 | 02:39 PM
Default Re: When does the walbro struggle (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Your injectors will be the limiting factor.
The walbro has made a tad bit over 600whp safely.</TD></TR></TABLE>
so the walbro will handle 4 bar fuel pressure plus 30psi of boost
Old Nov 14, 2006 | 02:44 PM
If you are trying to 'cheat' your injectors with 59psi of fuel pressure, you will more than likely max your injectors out just shy of 500whp. The last set-up I tried to 'cheat' this way reached 100% duty cycle at 480whp. I believe we were running 23psi with the walbro hp 255.
Also, when asking questions like this it's good to keep your units identical to one another (bar/psi).
So you are basically looking at running 90psi of fuel pressure... that graph should give you an answer
Old Nov 14, 2006 | 03:37 PM
Tchleung's Avatar
It depends on the fuel pump voltage as well. with a voltage booster to 16+ Voltes, it can handle alot mroe power
Old Nov 14, 2006 | 03:41 PM
b20turboic's Avatar
Default Re: (Tchleung)
But if you are going to cheat it with more piggy back stuff ... why not do it right ??
Old Nov 15, 2006 | 05:23 AM
Wilky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">It depends on the fuel pump voltage as well. with a voltage booster to 16+ Voltes, it can handle alot mroe power</TD></TR></TABLE>
Won't this cause premature wear on the unit? Just curious.
Old Nov 15, 2006 | 05:54 AM
b18sihatch's Avatar
Default Re: (Wilky)
i couldnt see how given they have higher ampage alternators that are naturally making more voltage than OEM so if thats the case then a higher ampage alt system would prematurely wear out a oem pump
higher voltage will just give it greater working ability
Old Nov 15, 2006 | 07:39 AM
Flashmn's Avatar
Default Re: (b18sihatch)
Fuel pump and alternator are different things. Alternator is governed by the charge governor, it would produce alot more voltage than 14.4V or so what it gives out when charging the battery, but the voltage governor doesnt allow it.
Old Nov 15, 2006 | 08:21 AM
b18sihatch's Avatar
Default Re: (Flashmn)
yea but the fuel pump is electric and you would think higher voltage from the alternator sent to the eletrical system would make the fuel pump work more
maybe i am wrong but it sounds right to me lol
money moe
Jan 22, 2006 08:12 PM
mp5o
Jan 1, 2006 02:11 PM
SpeedingHatch
Dec 31, 2005 02:41 PM
wpgcivic
Dec 31, 2004 01:33 PM
adhana2
May 22, 2003 05:26 PM
