what to do...
Old Nov 7, 2006 | 08:15 AM
nboost's Avatar
Default what to do...
Ive been wondering what i could do to not only feed my turbo but also put a oil pressure sender somewhere on my motor. i know people are using sandwich plates but would a sandwich plate also be wide enough to screw a sender on?
I could use the factory oil pressure sender location but i dont know if i can find an adapter with 4 orfaces to screw into the block, feed the turbo,put my pressure sender to run to a guage on and put the factory sender on.......? is the factory sender necessary? i have an obd1 car and id imagine it would throw a code...
Old Nov 7, 2006 | 08:17 AM
BoostedEG6's Avatar
Default Re: what to do... (nboost)
if you dont want to run a sandwich then get a fitting and run a single line to a 4 way T on the firewall and you will be fine. I got my brass 4 way at homedepot
Old Nov 7, 2006 | 09:53 AM
rmcdaniels's Avatar
I used a sandwich and remote mounted my oil pressure sender on the firewall. I got some 100+ PSI rated fuel injector line from NAPA and used a hose barb on either end.
DannyDeuce
May 2, 2006 01:51 PM
StylishDOHC
Apr 4, 2006 09:02 PM
Del_Slowest
Nov 20, 2003 11:55 AM
egturbo
Jul 19, 2003 06:54 PM
slo blue
May 27, 2002 08:30 PM
