ARP Nut's and washers?
Old Nov 11, 2006 | 03:04 PM
Tippyman's Avatar
Default ARP Nut's and washers?
I installed some ARP headstuds today.
1) They came with washers and nuts. I assume I put the washer over the stud, then the nut, then torque it down?
2) Also, Do I torque themall down to 22 ft lbs first, then 65? I've never torqued anything down before, so I need help.
Doing all of this tomorrow. Thanx for your help!
-Tippyman.
Old Nov 11, 2006 | 04:01 PM
bb_one's Avatar
Default Re: ARP Nut's and washers? (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
Yes.
-Tippyman.</TD></TR></TABLE>
Also yes, follow the torque process specified on the spec sheet with your head studs, they will tell you what your final troue value would be as well. I prefer a 3 step torque process rather then 2 (22, 50, 70). Also remember to tighten it down in the crisscross pattern.
Old Nov 11, 2006 | 05:52 PM
a1320addict's Avatar
Default Re: ARP Nut's and washers? (bb_one)
Weird, I did my ARP's today as well.
I used the molylube, tightened the studs into the block a hair under 10 ft/lbs. Copper sprayed the new OEM gasket, put the head back on, washers and molylubed the inside of the nuts, then torqued.
I did a 2-step torquing, first was 25 ft/lb, followed by 70 ft/lb in the sequence in the Hayne's. After reseraching a lot regarding the torque process for the studs, it seems all that is needed is a 2-step process, as more smaller steps put more stress on the threads. Also, OEM calls for only a 2-step process.
Old Nov 11, 2006 | 06:20 PM
mike93eh2's Avatar
i could be wrong but i think the nut goes on first and then the washer ont op of the nut..
Old Nov 11, 2006 | 06:21 PM
Default Re: ARP Nut's and washers? (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">
i could be wrong but i think the nut goes on first and then the washer ont op of the nut.. </TD></TR></TABLE>
nope
Old Nov 11, 2006 | 06:42 PM
mike93eh2's Avatar
Default Re: ARP Nut's and washers? (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">nope </TD></TR></TABLE>
really?
Old Nov 11, 2006 | 08:22 PM
think of what you're saying, how could that physically work?
Old Nov 11, 2006 | 08:35 PM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">think of what you're saying, how could that physically work? </TD></TR></TABLE>
i was making fun of the op's question lol. you should be asking him to think of whast he was saying
Old Nov 12, 2006 | 01:44 AM
quik sol's Avatar
i stepped mine up 4 times...20-35-55-70
Old Nov 12, 2006 | 07:49 AM
HamiltonRex's Avatar
Default Re: (quik sol)
with the supplied lube i tq 78ft/lbs.
Old Nov 12, 2006 | 10:16 PM
DragWerks's Avatar
Default Re: (HamiltonRex)
^^ correct... use generous amounts of lube on the washers, nuts and threads. I always do steps of 20 (20-40-60-78-78). don't forget to start from the middle studs and work your way out...
Old Nov 13, 2006 | 10:10 AM
Attoir's Avatar
Default Re: (DragWerks)
Oh yeah? Well I always do steps of .5 ft/lbs when I'm installing my head studs.
.5, 1.0, 1.5, 2.0, etc.
Takes a while, but it works, so my way is the only right way! Just FYI. :-P
Old Nov 13, 2006 | 04:59 PM
Default Re: (Attoir)
lmfao
GriFFIthS
Honda Civic (2001 - 2005)
10
Nov 13, 2008 10:40 PM
IA95civicDX
10
Jun 18, 2007 08:51 AM
lx-sedan
Jun 24, 2006 05:31 AM
92ehatch
Oct 7, 2005 04:19 PM
graslut
Aug 16, 2005 04:22 AM
