weird idle
Old Nov 9, 2006 | 10:59 PM
playahwitgame's Avatar
Default weird idle
so i have a 2000 gsr t. when i got it tuned, it didnt have any issues other then starting up kind of, but it starts fine now. but recently since it started to get colder, when the engine is cold, it will go form 2000 rpms-1500 then back up. and it will continue to do this until the car warms up a bit then everyhting will be cool. does this sound like its tune, weather, or idle control valve problem?
Old Nov 9, 2006 | 11:46 PM
mRek9R's Avatar
Default Re: weird idle (playahwitgame)
Sounds normal to me...the engine is building heat at a much faster rate if it idles at 1.5k to 2k, then when she's all warmed up, 800-1k.
Old Nov 10, 2006 | 03:46 AM
boosted k20's Avatar
Default Re: weird idle (mRek9R)
thats nromal. most chipped ecu's tuned on crome, uber,hondata will have a weird cold ilde start. my car with crome wont even idle unless i give it gas when its cold. after it warms up everything is good.... nothings perfect
Old Nov 10, 2006 | 05:08 AM
miller's Avatar
Default Re: weird idle (boosted k20)
you guys ever heard of coolant temp comp maps?
Old Nov 10, 2006 | 05:27 AM
Default Re: weird idle (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">you guys ever heard of coolant temp comp maps?</TD></TR></TABLE>
coolant temp maps work to some extent, but some programs will still give u buggy idle
Old Nov 10, 2006 | 10:01 AM
EK k kay's Avatar
I'm tuned with crome and dsm 450's and I've had a buggy on and off surging idle like from 1100-1500 ever since I switched to obd1 whether it was on a basemap or on the tuned map.
Old Nov 10, 2006 | 11:07 AM
miller's Avatar
Default Re: weird idle (EK k kay)
i would understand if it was 1600cc injectors and you couldnt get a " perfect " idle, but with anything else you should not have a problem getting the car to idle at 8-900 rpm perring like a kitten.
The biggest thing i have seen is that people never touch the the water or air temp comp's and think they are fine where they are, but hey to each their own.
Old Nov 10, 2006 | 11:21 AM
so nothing to worry about? i think im goign to clean out my iacv when i have time, but its not a problem?
Old Nov 10, 2006 | 01:08 PM
"I'm tuned with crome and dsm 450's and I've had a buggy on and off surging idle like from 1100-1500 ever since I switched to obd1 whether it was on a basemap or on the tuned map. "
w/ crome u need to calibrate the TPS to get the idle to smoothen out better.
Old Nov 10, 2006 | 06:31 PM
miller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">
you should calibrate any tps, with any ecu on any car when tuning if it is not correct.
Old Nov 10, 2006 | 07:52 PM
not2slo128's Avatar
"<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">you guys ever heard of coolant temp comp maps?</TD></TR></TABLE>
Can you recommend a set of values to try (see below)
http://uberdata.pgmfi.org/foru...=4279
My warm idle is often erratic and the car requires throttle input to start once it's been driven for a while.
Thanks.
Old Nov 11, 2006 | 07:55 AM
not2slo128's Avatar
Default Re: weird idle (not2slo128)
bump
Old Nov 11, 2006 | 01:15 PM
not2slo128's Avatar
Old Nov 13, 2006 | 02:06 PM
not2slo128's Avatar
bump
napalm588
Jan 16, 2008 02:34 AM
mike93eh2
Jul 17, 2007 07:45 PM
LudEnthusiast
Jul 5, 2005 10:37 AM
jdmstreethatch
13
Apr 5, 2004 11:09 AM
crx00
Mar 13, 2004 06:39 AM
