Wiring and installing an aem 5 bar map sensor
Old Nov 12, 2006 | 07:12 PM
CustomX113's Avatar
Banned
Default Wiring and installing an aem 5 bar map sensor
just bought a aem 5 bar map and was wondering if anyone had any links or sites thats shows installation of these, you have to drill and mount it on the mani but im not sure where... im not going to be pushing more then 20psi will the 5 bar be good or should i get a 3 bar?
Old Nov 12, 2006 | 07:15 PM
vaporboy12's Avatar
Default Re: Wiring and installing an aem 5 bar map sensor (95dxb18c1)
DO NOT mount it on the manifold bad idea it willnt last long. its the same wiring as the 3 bar
Old Nov 12, 2006 | 07:30 PM
CustomX113's Avatar
Banned
Default Re: Wiring and installing an aem 5 bar map sensor (vaporboy12)
the guy i bought it from said it gets mounted on the mani... i am a newb at hooking up aftermarket map sensors...
Old Nov 12, 2006 | 07:34 PM
vaporboy12's Avatar
it will get fucked up from the vibes from the motor.
Old Nov 12, 2006 | 07:56 PM
integra_gsr98's Avatar
Shitty picture but you can see the AEM 5 bar mounted to the firewall in a little loop. Cost like $0.29 to mount and has worked out very well.
This winter I will be switching to a steel braided vacuum feed to it as I had an issue w/ a cut vacuum line this last season mess with me for a little bit, so that is another recommendation I can give as well.
Old Nov 12, 2006 | 08:25 PM
CustomX113's Avatar
Banned
Default Re: Wiring and installing an aem 5 bar map sensor (integra_gsr98)
so you ran a vacuum line from the map sensor on the firewall to the tb? how did you connect the vacuum line to the map sensor opening on the tb and the sensor?
Old Nov 12, 2006 | 08:28 PM
The map sensor is fed off of a vacuum source off of the back of the intake manifold. I have the vacuum line attached to it w/ an 1/8" NPT Female to Hose Barb adapter that came w/ the map sensor.
If you bought it used, any hardware store should have that adapter.
Old Nov 12, 2006 | 08:35 PM
CustomX113's Avatar
Banned
ok, so you just fed it off the little nipple on the back of the intake mani, easy enough, yeah i bought it used so ill have to go to the hardware store and pick up the adapter. so i take it you just left the stock map sensor on the tb?
Old Nov 12, 2006 | 08:45 PM
iBrandon's Avatar
Default Re: (95dxb18c1)
i Have a jg manifold...and i had it mounted there...no probs yet..but u guys are making me second guess if i should moutn it to the fire wall...has anyone experiece failure on these when moutned to the mani?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">ok, so you just fed it off the little nipple on the back of the intake mani, easy enough, yeah i bought it used so ill have to go to the hardware store and pick up the adapter. so i take it you just left the stock map sensor on the tb?</TD></TR></TABLE>
Correct. It's just there to plug the hole.
Old Nov 12, 2006 | 08:48 PM
CustomX113's Avatar
Banned
Default Re: (integra_gsr98)
sweet, ok got it, thanks for the help
Old Nov 12, 2006 | 08:52 PM
vaporboy12's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon &raquo;</TD></TR><TR><TD CLASS="quote">i Have a jg manifold...and i had it mounted there...no probs yet..but u guys are making me second guess if i should moutn it to the fire wall...has anyone experiece failure on these when moutned to the mani?</TD></TR></TABLE>
ive been told by people they go bad when they are the intake manifold i didnt want risk finding out so i just made a stainless line and put it on the fir wall
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">sweet, ok got it, thanks for the help </TD></TR></TABLE>
hey i got a 1/8 female to barb and a 1/8th to -4an if you are intrested just pay me a few bucks plus shipping
Old Nov 12, 2006 | 09:19 PM
shortyz21's Avatar
Default Re: (vaporboy12)
why would a 3 bar not be good enough?
thats like 42 psi..
Old Nov 12, 2006 | 09:22 PM
vaporboy12's Avatar
Default Re: (shortyz21)
no a 3 bar is 29psi or so 1 bar vacum 2 bar boost 5 bar is 1 bar vacum and 4 bar of boost about 58psi
Old Nov 13, 2006 | 07:37 AM
shortyz21's Avatar
ah.
so its 3 bar absolute pressure.
Old Nov 13, 2006 | 07:55 AM
TheWickedOne's Avatar
Mount it one of the hardlines on the firewall and zip tie the snot out of it ..
Like others said .. run a barbed fitting on the sensor then vacum to a 1/8 nipple on the manifold.. connect with a vacum linie..
As for wiring .. wire it up like a 3-Bar...
Old Mar 23, 2008 | 11:20 AM
SPOOLINmatt's Avatar
Default Re: Wiring and installing an aem 5 bar map sensor (CustomX113)
only bumping this to enter in some info that i couldn't find or read wrong answers.
when going from a GM 3 bar to an AEM 5bar....swap the B and C wires around. Do not wire the sensor A-A, B-B, C-C because it wont work Reverse B and C
Thank you.
Old May 4, 2009 | 08:02 PM
jdm inc's Avatar
Thank you.
could i get more info on this wiring...
Old May 5, 2009 | 05:14 AM
dephtone's Avatar
Like this but reverse B and C. B would connect to Yellow/Red and C would connect to White.
Old May 5, 2009 | 05:37 AM
jdm inc's Avatar
awesome thanks!
wickedEFguy
Mar 7, 2008 11:55 AM
letitroll
Aug 5, 2007 04:54 PM
BB6-213
Apr 27, 2007 03:54 AM
Brian_92GSR
May 2, 2006 03:15 PM
fqnjdmboy
Mar 25, 2005 01:08 PM
