Finally finished my setup!!
Old Nov 10, 2006 | 08:09 PM
nebulight's Avatar
Default Finally finished my setup!!
Well, here is another B-Series turbo car *yawn* I went up to Evans-Tuning to get tuned. Well to say the least, the tuning session went GREAT today. I was worried that something would go wrong, but nada. I was more worried about my head gasket since I did the head studs one at a time and didn't replace the original head gasket. I thought maybe with the introduction of boost would kill the gasket, but everything went smooth. Here is the setup:
Motor:
Stock B18C1
ARP Head Studs
Full-Race Cam Gears
Edelbrock Victor X Intake Manifold
OEM GSR Throttle Body
Yonaka Dual Core Radiator with Slim Fan
Energy Suspension/Prothane Motor Mount Inserts
Turbo:
Full-Race Pro-Street Manifold
Full-Race 3 Inch DP
Thermal R&D 3 Inch Exhaust
Tial 50mm BOV
Tial 44mm Wastegate
RLD-Fab Wastegate Dumptube
Precision SC6152e 4 Bolt .63 a/r Turbo
Precision AS1025 600hp Medium FMIC
2.5" IC Pipes
Fast-Turbo Oil Lines w/ Sandwich
ECU:
P28 OBD1 ECU
GM 3 Bar Map Sensor
Neptune (with the RTP preordered)
Boomslang OBD2a to OBD1 Harness
Fuel:
Precision 1000cc Injectors
Custom Fuel Harness w/ OBD1 Clips
Walbro 255LPH In-Tank Fuel Pump
OEM GSR Fuel Rail
OEM GSR Fuel Pressure Regulator
Transmission:
Competition Clutch Stage 4 Sprung 6 Puck
Competition Clutch Ultra Lightweight Flywheel
OEM GSR Diff
OEM GSR Transmission
OEM GSR Axles
Energy Supension Shifter Bushings
Interior:
Stewart Warner 100PSI Oil Pressure Gauge
Stewart Warner 40PSI Boost Gauge
PLX M-300 Wideband O2 Sensor
OEM Acura Carbon Fiber Shift ****
Suspension:
Pro-Kit Springs
KYB AGX Shocks
15" SSR Competition Rims
Numbers are what everyone is interested in:
The car is simply amazing, but he detuned it since it's my daily driver, it sits in at around 360ish whp at 10psi with it creeping up to 11-12 closer to redline. I was amazed at how fast/good Jeff tunes, it's amazing to watch him work.
I would like to thank the following members from honda-tech for the purchases made since most of the parts came from here:
farturbo (Turbo Bret) - Full-Race Manifold
RLD-Fab - Dumptube
Evans-Tuning - Downpipe, Tuning
ham - FMIC Core
D@nnY- SC61
.::Lee::. - Fuel Harness and Resistor Box
DSF - Tial BOV
Airbag Club - P28 ECU
Naudlee - Oil Pan
reactiondc2 - IC pipes
N20civicB18 - ECU Harness
SFWD 1934 - Cam gears (Didn't even use )
Infinite Auto - Radiator and Fan (AWESOME GUY to deal with)
stockredej1 - 3 Bar Map
Samuels - Wideband
TurboFTW - Injectors
AF-Performance - Exhaust, Head Studs, Wastegate
Arturbo - Clutch, flywheel
Stan from Fast-Turbo - Oil lines, fuel pump, oil fittings, adapter, endyn breather, ect (Tons of ****, lol )
That pretty much sums it up. I may have missed a few people, but that's all I have bookmarked. I've posted pics in other threads, but here are a few:
Old Nov 10, 2006 | 08:18 PM
Bailhatch's Avatar
Default Re: Finally finished my setup!! (nebulight)
looks like a great tune gotta love that flat Tq
Old Nov 10, 2006 | 10:39 PM
a1320addict's Avatar
Default Re: Finally finished my setup!! (Bailhatch)
Saw the chart up on Jeff's site, car is making some great power for such a simple setup Awesome torque line....
Gonna take it to the track in the last few days we have here in tri-state?
Old Nov 11, 2006 | 06:16 AM
JDM_EM1's Avatar
Default Re: Finally finished my setup!! (a1320addict)
very nice, money well spent
Old Nov 11, 2006 | 07:25 AM
b18sihatch's Avatar
Old Nov 11, 2006 | 07:40 AM
platinum00's Avatar
Default Re: Finally finished my setup!! (b18sihatch)
nice powerband. i bet that if fun on the street
platinum.
Old Nov 11, 2006 | 11:30 AM
SD_Lurker's Avatar
HT White Ops
nice
Old Nov 11, 2006 | 11:40 AM
sleeprhatch's Avatar
Default Re: Finally finished my setup!! (nicks_jdmstyle_ef9)
wrd nice numbers,
Old Nov 11, 2006 | 11:46 AM
BoOsTeD C1's Avatar
nice numbers....I assumed you already fixed that overheating issue awhile back?
Old Nov 11, 2006 | 11:49 AM
vaporboy12's Avatar
Default Re: (BoOsTeD C1)
nice numbers glad to see everything worked out for you
looks like it will be a fun car to drive on the street
Old Nov 11, 2006 | 02:09 PM
drintegra's Avatar
nice set up, HOpe to be at the same level soon. How much psi before the de tune?
Old Nov 11, 2006 | 02:28 PM
Kev-turboEJ1's Avatar
Default Re: Finally finished my setup!! (drintegra)
Sweet numbers/setup
Old Nov 11, 2006 | 03:29 PM
nebulight's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drintegra &raquo;</TD></TR><TR><TD CLASS="quote">nice set up, HOpe to be at the same level soon. How much psi before the de tune?</TD></TR></TABLE>
hehe, I don't trust basemaps, so I was running stock ECU, stock Map sensor and stock injectors, so I wasn't running any boost before this. So needless to say, it was THRILLED to finally drive the car with boost and even more thrilled to have that much power!!
Old Nov 12, 2006 | 12:11 AM
D@nnY's Avatar
the car came out great man im glad to see your work paid off. with street tires on a daily driver thats a great setup theres not alot on the road that will beat you . good job man
Old Nov 12, 2006 | 09:34 AM
SpooledT3's Avatar
Default Re: (D@nnY)
nice setup
Old Nov 12, 2006 | 01:35 PM
boosted k20's Avatar
Default Re: (ef-t3)
good numbers! build that motor and turn the boost up!
Old Nov 12, 2006 | 02:07 PM
nebulight's Avatar
Default Re: (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">good numbers! build that motor and turn the boost up!</TD></TR></TABLE>
That's the plain, I bought a C5 block and an LS crank. Going to send the Block out to be sleeved soon.
Old Nov 12, 2006 | 02:16 PM
JDMisGOOD's Avatar
Default Re: (nebulight)
Very nice!
Old Nov 12, 2006 | 03:01 PM
xenocron's Avatar
Default Re: (JDMisGOOD)
Good stuff
Old Nov 12, 2006 | 03:58 PM
Quickgti1.8t's Avatar
Default Re: (xenocron)
weak I wish my POS can make that power at low boost
Old Nov 12, 2006 | 04:05 PM
sc4dr's Avatar
Default Re: (Quickgti1.8t)
Thats because its a volkswagen
Old Nov 12, 2006 | 04:51 PM
nebulight's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickgti1.8t &raquo;</TD></TR><TR><TD CLASS="quote">weak I wish my POS can make that power at low boost</TD></TR></TABLE>
Hey man, what are you doing in these parts of the woods?
Old Nov 12, 2006 | 06:55 PM
KineticMotorsport's Avatar
Lookin good Matt, can't wait to see what you have in store for us
Old Nov 12, 2006 | 06:59 PM
B.'s Avatar
B.
400 HP Club
Default Re: Finally finished my setup!! (KineticMotorsport)
nice build..
Old Nov 12, 2006 | 07:04 PM
IT'S ME DAVID's Avatar
NooB
nice numbers.show us the track slip once u finish ripping on it.
