safe to drive car?
Old Nov 7, 2006 | 09:23 PM
MJobe's Avatar
Default safe to drive car?
i recently put on my greddy turbo kit on my da w/ a jdm gsr swap . i havent takent it out of the garage yet or even started it .
basically my question is is it ok/safe to drive my car with 550's and a stock fuel pump with low boost? (under7lbs) will it be enough?
i REALLY appreciate the help!
and yes i did search
mike
Old Nov 7, 2006 | 10:31 PM
quik sol's Avatar
ive had a motor blow at 4.5psi...drive it, fine...just dont let it build boost (when ya drive it, swap back in the stock injectors and leave the 550's until ya get it tuned)
Old Nov 8, 2006 | 01:18 AM
01geeser's Avatar
New User
Default Re: (quik sol)
your car wont idle with 550's unless you have a basemap/management.
Old Nov 8, 2006 | 06:46 AM
aaronISthrowed's Avatar
Default Re: (01geeser)
Use the stock injectors and you should be able to drive but DONT go into boost. You will only be able to use those injectors if you get a basemap.
Old Nov 8, 2006 | 08:15 AM
b18sihatch's Avatar
Default Re: safe to drive car? (JOBEYYYYY)
what kinda ems are you going to be using
Old Nov 8, 2006 | 08:29 AM
MJobe's Avatar
Default Re: safe to drive car? (b18sihatch)
i will be using a safe basemap (for 550's) from phearable.net, so is it possible to drive it with the stock fuel pump at low boost?
thanks once again
Old Nov 8, 2006 | 08:34 AM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOBEYYYYY &raquo;</TD></TR><TR><TD CLASS="quote">i will be using a safe basemap (for 550's) from phearable.net, so is it possible to drive it with the stock fuel pump at low boost?
thanks once again </TD></TR></TABLE>
no such thing as a safe basemap. a basemap is just a guess. like everybody said already. just stay out of boost and you will be fine.
Old Nov 8, 2006 | 08:38 AM
MJobe's Avatar
Default Re: safe to drive car? (komat)
when running the 550's will i be maxxing out my stock fuel pump?
Old Nov 8, 2006 | 08:55 AM
MJobe's Avatar
ttt
Old Nov 8, 2006 | 09:23 AM
MJobe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOBEYYYYY &raquo;</TD></TR><TR><TD CLASS="quote">ttt</TD></TR></TABLE>
Old Nov 8, 2006 | 09:30 AM
b18sihatch's Avatar
IMO its a good idea to get a aftermarket fuel pump.
the injectors can flow more than stock
sowhat about the fuel pump, it can flow for stock injectors, but a high flow fuel pump is what you wanna get
you want equal flow from both injectors and fuel pump.
not just high flow from the injectors
Old Nov 8, 2006 | 09:32 AM
MJobe's Avatar
but would i be safe to drive it for about a week until i get my paycheck ?
car pooling with the g/f is killing me , literally lol
Old Nov 8, 2006 | 10:44 AM
MJobe's Avatar
up
Old Nov 8, 2006 | 11:02 AM
I guess it would be fine as long as you drive like a grandma. I'm not 100% sure about this tho.
Old Nov 8, 2006 | 11:36 AM
4thgenner's Avatar
if your on a basemap it will be fine to drive off boost. just don't build boost.
Old Nov 8, 2006 | 04:14 PM
ProjectDarkBlack's Avatar
NO BOOST! and you will be fine. get it tuned
jamesfawcett
Apr 13, 2010 01:33 AM
ketchup!
Sep 9, 2006 07:42 PM
si tuner
Jul 31, 2004 03:25 PM
Tofurky
Jan 6, 2003 04:39 PM
integra-modder
Sep 19, 2002 04:52 PM
