D15B7 with H22A injectors?
Old Nov 9, 2006 | 11:40 AM
wolve's Avatar
Default D15B7 with H22A injectors?
i need a cheap way to fulfill my injector needs. i'm going budget turbo for ***** and giggles on my d15b7 (got my hands on a free td04l).
now the problem is that i live in holland, there are no dsm's or alike that i can strip some 450's from. now i am told 310 cc wil get me slightly over 200-210whp.luckely that seems to be the limit for the almighty d15
my question is: how much cc are the h22a's injectors and do they fit the d15b7?
i'll probably end up buying a new fuel pump so upping the pressure won't be that much trouble
Old Nov 9, 2006 | 11:59 AM
pheurton-skeurto's Avatar
if i remember correctly they are 310's.
Old Nov 9, 2006 | 12:00 PM
by the way also...ive had a ton of fun with my junkyard turboing of my d15b7. over 200000miles and it loves getting beat on.
Old Nov 9, 2006 | 12:08 PM
wolve's Avatar
Default Re: (pheurton-skeurto)
that's great
do they fit a d15b7???
Old Nov 9, 2006 | 12:35 PM
wolve's Avatar
Default Re: (wolve)
anyone??
Old Nov 9, 2006 | 12:37 PM
Built2.0Lude's Avatar
no not 310cc...
OBD1 - peak and hold - 345cc
OBD2 - saturated - 290cc
couldnt tell ya if they would fit or not but im sure they would fit one way or another.
Old Nov 9, 2006 | 12:41 PM
wolve's Avatar
Default Re: (Built2.0Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2.0Lude &raquo;</TD></TR><TR><TD CLASS="quote">
OBD2 - saturated - 290cc</TD></TR></TABLE>
good info
since i have a obd1 civic coupe, wich would work with my system: the saturated or the peak and hold?
Old Nov 9, 2006 | 12:43 PM
obd1 car, obd1 injectors... in other words peak and hold
Old Nov 9, 2006 | 12:47 PM
wolve's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2.0Lude &raquo;</TD></TR><TR><TD CLASS="quote">obd1 car, obd1 injectors</TD></TR></TABLE>
great news, 345cc would give me some more room to safely blow it up
maybe it won't blow up till 220 or maybe even more
but the qeustion remains, will they fit?????
Old Nov 9, 2006 | 01:03 PM
i know for sure that theyll fit. youll probably want to get a new injector grommet kit or whatever from napa. itll have all of the small rubber grommets that you need/that are all effed up from before.
i run a resistor box in both of my cars-d15b7 and my h22a4. i have dsm 450's in both also. so im pretty damn sure that if you run the obd1 prelude injectors then youre gonna need a resistor box ($20 max...junkyard, ebay, a friend, etc.). but to say obd1 to obd1 is not exactly true.
Old Nov 13, 2006 | 10:52 AM
wolve's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pheurton-skeurto &raquo;</TD></TR><TR><TD CLASS="quote">i know for sure that theyll fit. youll probably want to get a new injector grommet kit or whatever from napa. itll have all of the small rubber grommets that you need/that are all effed up from before.
i run a resistor box in both of my cars-d15b7 and my h22a4. i have dsm 450's in both also. so im pretty damn sure that if you run the obd1 prelude injectors then youre gonna need a resistor box ($20 max...junkyard, ebay, a friend, etc.). but to say obd1 to obd1 is not exactly true.</TD></TR></TABLE>
for sure
can you run the obd2 like plug and play then? i'm trying to add as less as possible, the less i ad, the less that can go wrong
and a resistorbox, wich one will do, not very familiar with resistorboxes
Old Nov 13, 2006 | 11:04 AM
AJxr's Avatar
Default Re: (wolve)
any resistor box will do. im using one from a ef SI and ive seen people use dsm ones, radio shack ones, and the ones from DA integras. the only difference with the obd2 injectors should be the plugs, and if they are saturdated you dont need to resistor box.
Old Nov 15, 2006 | 09:11 AM
wolve's Avatar
Default Re: (AJxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJxr &raquo;</TD></TR><TR><TD CLASS="quote">any resistor box will do. im using one from a ef SI and ive seen people use dsm ones, radio shack ones, and the ones from DA integras. the only difference with the obd2 injectors should be the plugs, and if they are saturdated you dont need to resistor box.</TD></TR></TABLE>
thnx for the info
what's your set-up, d15t???
WOW !
Jan 7, 2012 07:01 AM
pcguy760
Jul 1, 2008 09:18 AM
prelude72569858
Jul 13, 2006 01:55 PM
nickwilmot
Dec 1, 2003 11:01 PM
se93
Feb 19, 2002 08:36 AM
