Factory oil cooler????
Old Nov 10, 2006 | 12:54 PM
gdh8su's Avatar
Default Factory oil cooler????
I am having a problem with alittle bit of black crap showing up in my overflow tank. I have replaced the headgasket and flushed the system and new studs. The head and block was checked and was within spec. I am using the factory ITR oil cooler with a Greddy oil cooler. Now the question is has anybody had a OEM Honda oil cooler fail and do the same thing? Also there is NO water in the oil!
Old Nov 10, 2006 | 01:00 PM
BoostedEG6's Avatar
Default Re: Factory oil cooler???? (gdh8su)
its probably coming from your Radiator..... is it stock?
Old Nov 10, 2006 | 01:46 PM
gdh8su's Avatar
Default Re: Factory oil cooler???? (BoostedEG6)
No it's a fluidyne.
Old Nov 10, 2006 | 01:56 PM
beepy's Avatar
Sounds like you recently had a head gasket problem? If so you probably just didn't get all the crap out when you flushed. Don't worry unless you get water in the oil.
Old Nov 10, 2006 | 05:36 PM
gdh8su's Avatar
Default Re: Factory oil cooler???? (beepy)
It did this 4 years ago when I first put it together. I had the time and motor out to replace the clutch. It was just bugging me. I replaced the gasket thinking that it was leaking. There were no signs of a blown gasket or warpage. The car never over heats even when it's a 90+ and humid out while racing it! Max temp I have ever seen was 200 in traffic before fan kicked on. It's just baffling me with bullshit!!
redh22alude
Dec 30, 2008 09:32 AM
Mike1995HondaPrelude
Nov 9, 2007 02:46 AM
ujhonda
May 11, 2006 04:29 PM
mingbling96
Jan 17, 2005 09:31 PM
OldSchoolCrxSiR
13
Jun 26, 2002 09:41 PM
