wont idle with 3 bar map
Old Nov 9, 2006 | 01:34 PM
jdmtuner012's Avatar
Default wont idle with 3 bar map
i am running a chipped ecu on a turbo b18b1, the car runs fine until you reprogram the ecu for use with a gm 3 bar. once you change to a 3 bar, the car wont idle anymore, i found instructions on several web sites and wired it up the way they all said, but i will not stay running. any help appreciated
Old Nov 9, 2006 | 01:41 PM
93turbo16's Avatar
Default Re: wont idle with 3 bar map (jdmtuner012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmtuner012 &raquo;</TD></TR><TR><TD CLASS="quote">i am running a chipped ecu on a turbo b18b1, the car runs fine until you reprogram the ecu for use with a gm 3 bar. once you change to a 3 bar, the car wont idle anymore, i found instructions on several web sites and wired it up the way they all said, but i will not stay running. any help appreciated</TD></TR></TABLE>
What basemap or sofrware are you using? It will more than likely need tuned right away.
Old Nov 10, 2006 | 04:26 AM
Default Re: wont idle with 3 bar map (93turbo16)
we are using a chipped ecu from phearable.net, with chrome for tuning, also we have the innovative motorsports lm-1 (lambda) air/fuel meter, with a bosch wideband
Old Nov 10, 2006 | 05:11 AM
twkdCD595's Avatar
what brand 3bar? gm or generic replacement 3 bar?
Old Nov 10, 2006 | 06:59 AM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmtuner012 &raquo;</TD></TR><TR><TD CLASS="quote">we are using a chipped ecu from phearable.net, with chrome for tuning, also we have the innovative motorsports lm-1 (lambda) air/fuel meter, with a bosch wideband</TD></TR></TABLE>
What is the wideband telling you then? I bet you add 20-30% of fuel to the 3bar map and it will idle.
Old Nov 11, 2006 | 06:13 AM
boosted k20's Avatar
most of the time it is an incorrect wiring that causes the car not to run with the 3-bar. with the car on datalog whats going on with the car. the car should be idling around 21 in-hg in the maps. if its idling in the boosted portion of the maps or at 0-psi then u need to rewire the map sensor. if everything is good, check the a/f and tune it out.
Civic89stdB16
Oct 11, 2007 02:47 PM
import810
Jul 17, 2007 11:34 PM
Pfieff
Sep 27, 2004 02:06 PM
Jdmgsr416
Feb 29, 2004 11:04 PM
