Vibrant Performance SEMA Turbo Engine Stand
Old Nov 8, 2006 | 07:01 AM
jdm4eva's Avatar
Default Vibrant Performance SEMA Turbo Engine Stand
Hey guys just wanted to show some pics of Vibrant Performance Turbo B-Series Engine stand that was at the SEMA show last week. Built by the guys @ ETD Racing (Newmarket, Canada)
Vibrant's New Quick Release Boost Brace (helps secure your intercooler piping)
Vibrant's New Aluminum Vacuum Manifold
Old Nov 8, 2006 | 07:36 AM
sohcT's Avatar
Default Re: Vibrant Performance SEMA Turbo Engine Stand (jdm4eva)
Very cool. What is that timing belt tensioner looking thing?
Old Nov 8, 2006 | 07:40 AM
Boostfed's Avatar
New User
Now that is a great idea!!!!!! Make it so much easier to tension the belt.
Also I like the IC piping locks, people been welding tabs across and using a bolt or so to hold it, good ideas
JoePSI's Avatar
Default Re: Vibrant Performance SEMA Turbo Engine Stand (sohcT)
I want more info on that cathcan setup!
Old Nov 8, 2006 | 07:53 AM
mike1114's Avatar
Default Re: Vibrant Performance SEMA Turbo Engine Stand (JoePSI)
nothing special about the catch can to me....looks like they just mounted it there to look cool.
I do also like the timing belt tensioner thing, it looks like it bolts to where the AC bracket/torqe mount was.....what about if your still using that mount?
Old Nov 8, 2006 | 07:54 AM
BoostedEG6's Avatar
I like the timing belt tension idea the best
Old Nov 8, 2006 | 08:08 AM
Mr.OB*GYN_Rhett's Avatar
Default Re: Vibrant Performance SEMA Turbo Engine Stand (BoostedEG6)
QR IC piping
Old Nov 8, 2006 | 08:26 AM
b18sihatch's Avatar
tensoner
Old Nov 8, 2006 | 08:32 AM
miller's Avatar
Default Re: Vibrant Performance SEMA Turbo Engine Stand (b18sihatch)
why would you need that tensioner? i have never had any issues with the belts on a b series.
Old Nov 8, 2006 | 08:35 AM
BoostedEG6's Avatar
Default Re: Vibrant Performance SEMA Turbo Engine Stand (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">why would you need that tensioner? i have never had any issues with the belts on a b series.</TD></TR></TABLE>
Maybe everyone’s not perfect like you j/k
I have never had any problems either but I think people that have had their heads and blocks decked have a little more slack than normal people do so it tightens it up a little
Old Nov 8, 2006 | 08:38 AM
Runnerdown's Avatar
because its a new product to sell duh!
Old Nov 8, 2006 | 08:48 AM
vaporboy12's Avatar
Default Re: Vibrant Performance SEMA Turbo Engine Stand (Runnerdown)
if you tension the belt the right way you dont need
Old Nov 8, 2006 | 08:50 AM
Kelly.'s Avatar
I've quit using this account
no pictures of the chick that was at the booth???
lol,
she was one of the hottest chicks there though (imo )
i have dealt with vibrant before, and they have good customer service and pretty good prices.
nice to see they are expanding thier product line alittle bit.
i especially like the fittings they used instead of vaccum lines,
i used to used the same fitting when i played paintball.
they are easy to deal with and seemed very durable.
the fact that i wont have to worry about blowing vaccum lines, will be well worth the cost to change over (the fitting are ~ $2 a piece)
Old Nov 8, 2006 | 09:04 AM
jdm4eva's Avatar
Default Re: (Kelly.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kelly. &raquo;</TD></TR><TR><TD CLASS="quote">no pictures of the chick that was at the booth???
lol,
the fact that i wont have to worry about blowing vaccum lines, will be well worth the cost to change over (the fitting are ~ $2 a piece)</TD></TR></TABLE>
Hey dude thanks for the compliments and our new product. Here is a link to some pics of Jayde and some vehicles that I posted in the appreance/comestic section
https://honda-tech.com/zerothread/1804407
Old Nov 8, 2006 | 09:14 AM
NIKE SB'd's Avatar
o boy
Old Nov 8, 2006 | 09:15 AM
Kelly.'s Avatar
ill be sending in another order shortly
keep up the great work.
Old Nov 8, 2006 | 09:20 AM
jdm4eva's Avatar
Default Re: Vibrant Performance SEMA Turbo Engine Stand (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">nothing special about the catch can to me....looks like they just mounted it there to look cool.
I do also like the timing belt tensioner thing, it looks like it bolts to where the AC bracket/torqe mount was.....what about if your still using that mount?</TD></TR></TABLE>
About the catch can, you can adjust the length of the can by cutting to whateva length you need. The end caps are removable so you can take it apart and clean it. We also sell the catch can with a mounting bracket that allows for 360degree adjustability.
To answer your other question if your using the tensioner you will have to relocate or removal your power steering pump.
Old Nov 8, 2006 | 09:21 AM
Muckman's Avatar
Moderator in Chief
If you used that tensioner would you keep the stock one loose? Not the bolt loose of course but the tensioner loose.
- I like how they put a flex pipe on the dumptube which is open dump and has no need for flex.
- You could never mount the catch can like that if you have a VTEC solenoid.
Old Nov 8, 2006 | 09:34 AM
Killerbreed's Avatar
Default Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">If you used that tensioner would you keep the stock one loose? Not the bolt loose of course but the tensioner loose.
- You could never mount the catch can like that if you have a VTEC solenoid.</TD></TR></TABLE>
I think they had the flex there for display purposes only. The engine (in my IMO) is an assortment of what you can do with their product. So in reality, the catch can is only mounted there for display purposes. If you bought it, you obviously would mount it differently......
Nice booth!
Old Nov 8, 2006 | 09:37 AM
ExospeedAMcrx's Avatar
the cam gear is stock with a cover?
Old Nov 8, 2006 | 09:39 AM
Bailhatch's Avatar
I thought we were gonna see a cool engine stand I love some of the displays shops make for shows.
The workmanship on everything looks pretty nice but I don't see the need for many of the parts. The tensioner is silly IMO. just another thing to break or wear out. It's all show parts...at a show, So i guess good job
Old Nov 8, 2006 | 10:02 AM
redboost10's Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">if you tension the belt the right way you dont need </TD></TR></TABLE>
x2
Old Nov 8, 2006 | 10:05 AM
Kelly.'s Avatar
Default Re: Vibrant Performance SEMA Turbo Engine Stand (vaporboy12)
if you strip the tensioner bolt (ive seen it happen when only tq'd to spec) would be nice to not have to throw out a freshly sleeved block.
all im sayin is that it is nice to have options
Old Nov 8, 2006 | 10:07 AM
Boostfed's Avatar
New User
Default Re: Vibrant Performance SEMA Turbo Engine Stand (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">the cam gear is stock with a cover?</TD></TR></TABLE>
Cool hubcaps for your cam gears!
Old Nov 8, 2006 | 10:22 AM
vaporboy12's Avatar
Default Re: Vibrant Performance SEMA Turbo Engine Stand (Boostfed.com)
[QUOTE=Kelly.]if you strip the tensioner bolt (ive seen it happen when only tq'd to spec) would be nice to not have to throw out a freshly sleeved block.
throw it out why? you can go to your local machine shop and rent a time sert kit for damn near nothing.. ive have been doing timing belts on honda's for 4-5 years now and ive never stripped a tensior bolt... just adding more moving part that could o bad and more wear on a belt. If honda wanted to put a tensior there they would have done it from the factory
