first turbo set up
Old Nov 12, 2006 | 04:42 PM
harley06's Avatar
Default first turbo set up
this is my first turbo set up im putting together and i just have a couple questions. im building a kit and i already have the manifold, t25 turbo, bov, intercooler, piping, and 370cc injectors.
what else do i need? i know i need a tapped oil pan, oil feed and return lines, colder spark plugs. what else do i need? fuel management unit?
do i need a fuel pressure regulator or will my injectors do the same thing?
Old Nov 12, 2006 | 04:54 PM
Schister66's Avatar
Man U FTW
what chassis and what engine?? You may have to get an OBD1 ECU and conversion harness if you're not OBD1...Is the turbo internally gated??
Old Nov 12, 2006 | 05:25 PM
harley06's Avatar
Default Re: (Schister66)
all the info about my car is in my sig.. yeah the turbo 7psi internal wastegated
so what else do i need? i know i need a tapped oil pan, oil feed and return lines, colder spark plugs. what else do i need? fuel management unit?
Old Nov 12, 2006 | 05:38 PM
aaronISthrowed's Avatar
Default Re: (harley06)
Yeah, you need a socketed ECU that can be tuned, a FMU and FPR will not be required. You also need a downpipe, couplers and t clamps, walbro fuel pump, and some other things check the FAQs. It helps out alot.
Old Nov 12, 2006 | 06:11 PM
harley06's Avatar
Default Re: (aaronISthrowed)
so i can get a chipped ecu and forget about the FMU and FPR? oh yeah i already have the tclamps and silicone couplers and downpipe
what kind of chipped ecu? where to get it? phearable.net? hondata?
Old Nov 12, 2006 | 07:10 PM
harley06's Avatar
whats the difference between a walbro 255lph fuel pump and a walbro 255lph HP fuel pump?
what would be better to get
Old Nov 12, 2006 | 08:11 PM
b18sihatch's Avatar
get the best ems you can as tuning is the main key in any turbo application, if money isnt a issue get the best
Old Nov 13, 2006 | 05:56 AM
harley06's Avatar
Default Re: (b18sihatch)
where can i get a chipped ecu.. will a ecu from phearable.net work perfectly fine?
Old Nov 13, 2006 | 06:33 AM
harley06's Avatar
which spark plugs??
ngk BKR7E or ngk BKR7ES-11
Old Nov 13, 2006 | 06:34 AM
BDogggUT34's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harley06 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of chipped ecu? where to get it? phearable.net? hondata?</TD></TR></TABLE>
The choice is yours, i will be sending Phearable my ECU to have it chipped with a Crome basemap. I'm not one to change things alot so after i have it tuned i'm letting it be. Thats why i'm going with the cheaper crome option. But the choice is yours, there are many threads comparing hondata to crome to uberdata etc, so i suggest you search for those and read up as i have been doing.
Old Nov 13, 2006 | 07:10 AM
Default Re: (BDogggUT34)
You can get one from phearable.net its up to you and what you want to tune with.
Old Nov 13, 2006 | 07:14 AM
harley06's Avatar
well im not sure what i want to choose to tune it.. i was thinkin about gettin a ecu from phearable and taking it to T1 to tune it
Old Nov 13, 2006 | 07:18 AM
Schister66's Avatar
Man U FTW
i got my ECU from http://www.j-k-tuning.com and no complaints here.....check the FAQ and you'll have a lot better idea of what you need
Old Nov 13, 2006 | 07:29 AM
harley06's Avatar
so after i get a chipped ecu from phearable, kenji or jktuning. it needs to be tuned with hondata, crome, uberdata, or neptune?
will it run good without getting a tune by either one of those?
Old Nov 13, 2006 | 08:23 AM
JoePSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harley06 &raquo;</TD></TR><TR><TD CLASS="quote">so after i get a chipped ecu from phearable, kenji or jktuning. it needs to be tuned with hondata, crome, uberdata, or neptune?
will it run good without getting a tune by either one of those?</TD></TR></TABLE>
You get a BASEMAP from one of those placees. That basemap is a temporary tune to get you to a tuner, you shouldn't boost on a basemap. A basemap is just an estimated tune based on the specifications of your engine. Get to a tuner as soon as you can. That is the proper way.
EDIT: I learned the hard way, do it right
Boosting on a modified basemap = Cheap
3 Stretched Rods
3 Bent valves
= not cheap.
300hp is boring anyway,jk
Modified by JoePSI at 9:40 AM 11/13/2006
EKris
May 15, 2007 09:58 PM
hot93honda
Feb 18, 2005 01:28 PM
prelude2.3turbo
Jul 11, 2004 10:44 PM
khmboostedeh2
Jun 10, 2004 10:15 PM
ACURACY_VTEC
Aug 13, 2002 11:11 AM
