Quick question about ressistors
Old Nov 12, 2006 | 06:53 PM
blue_hatch's Avatar
Default Quick question about ressistors
i had 450's on my car hooked up with oem ressistor box. but im gonna run n/a over winter... can i run stock injectors with the ressistor box? i would take it out but dont know which wires goes to which injector, its too complicated.
Old Nov 12, 2006 | 10:09 PM
DragWerks's Avatar
Default Re: Quick question about ressistors (blue_hatch)
technically, you can run obd0 (88-91) injectors with the resistor box. In reality (flame suit on) you can mix hi and low impedence injectors usually without any problems.
Old Nov 13, 2006 | 08:06 AM
blue_hatch's Avatar
Default Re: Quick question about ressistors (DragWerks)
i wanna put obd-1 injectors back on with the ressistor still hooked up. the ressistor is all solder up and i dont want to rewire it cause its gonna be a b*tch
Old Nov 13, 2006 | 08:15 AM
mec. pedri's Avatar
get some 90-91 intrega injectors and it will be plug and play!
Old Nov 13, 2006 | 08:32 AM
blue_hatch's Avatar
Default Re: (mec. pedri)
its for my obd-1 car so i only got obd-1 injectors
Old Nov 13, 2006 | 08:38 AM
BoostedEG6's Avatar
Default Re: (blue_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue_hatch &raquo;</TD></TR><TR><TD CLASS="quote">its for my obd-1 car so i only got obd-1 injectors</TD></TR></TABLE>
That doesn’t matter as long as you are running the resistor box.... I don’t think you will have to modify anything to plug them in either (but I could be wrong not 100% sure)
Old Nov 13, 2006 | 08:44 AM
blue_hatch's Avatar
Default Re: (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">
That doesn’t matter as long as you are running the resistor box.... I don’t think you will have to modify anything to plug them in either (but I could be wrong not 100% sure)</TD></TR></TABLE>
what i mean is that i have only a set of obd-1 injectors, im not gonna spend money to buy some 0bd-0 injectors
Old Nov 13, 2006 | 08:58 AM
Dueceification's Avatar
i have a set of 240cc honda injector that require the resistor box cheap too $30/shipped and their urs
Old Nov 13, 2006 | 10:25 AM
lightcrx's Avatar
you can go to any pick n pull type of jy and get them for admission
Old Nov 13, 2006 | 01:21 PM
DragWerks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue_hatch &raquo;</TD></TR><TR><TD CLASS="quote">what i mean is that i have only a set of obd-1 injectors, im not gonna spend money to buy some 0bd-0 injectors</TD></TR></TABLE>
why are you asking the question if you know you're not gonna buy any other injectors? Just put your stock ones back in... it will run fine.
beansandrice
33
Sep 8, 2009 04:18 PM
CRX44
Aug 31, 2009 11:13 PM
dropNdestroyEF
Sep 12, 2008 05:47 AM
cor4ey
Nov 4, 2007 05:06 PM
fourthgenhatchB17
Apr 26, 2004 10:01 AM
