B18c1 block with a B16 head?
Old Nov 11, 2006 | 02:25 PM
Unsought Devil's Avatar
Default B18c1 block with a B16 head?
I have a B18C1 that I'm building up for a turbo. A few people told me to use a B16 Head. Does it make a Dif our is it the right way to go. I am machining already ported and polished the block with block guards. IF i use the B18 head or get a B16 head I will be machine it also.
Does and one have any sugestions on what internals I should go with( ie. Rods,pistons,valves,spring, and so on)
Its going in a 98EK hatch
Old Nov 11, 2006 | 02:49 PM
97CWITR's Avatar
Default Re: B18c1 block with a B16 head? (Unsought Devil)
did they tell you why you should use the b16 head?
the only thing that would be beneficial about doing that would be losing a little bit of compression from the larger combustion chamber.
gsr cams > b16 cams
there is a post somewhere that shows the flow chart for the b16 and b18c1 heads, and they are really close...why spend the money?
Old Nov 11, 2006 | 03:10 PM
b18sihatch's Avatar
b16 heads flow better than gsr heads which is a big factor in a turbo setup
the gsr cams are better than b16 however you can swap the gsr camshafts in the b16 so the head would be much better over gsr
if the head is PNP then it would have great flow ability
Old Nov 11, 2006 | 03:15 PM
shant's Avatar
Default Re: B18c1 block with a B16 head? (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">b16 heads flow better than gsr head</TD></TR></TABLE>
i dont know much about boost but that sounds interesting.
Old Nov 11, 2006 | 03:19 PM
b18sihatch's Avatar
Default Re: B18c1 block with a B16 head? (shant)
basicly the TYPE R head is a b16 head with better a slightly better valve train
the itr head is also pnp from factory.
b16 is a all overall better head
with the expection of the gsr camshafts being better in the gsr head
Old Nov 11, 2006 | 04:15 PM
95dc2teg's Avatar
so a good set up for turbo would be a b16 head with gsr cams?
Old Nov 11, 2006 | 04:57 PM
b18sihatch's Avatar
Default Re: B18c1 block with a B16 head? (95dc2teg)
IMO just a b16 head will do some good in a turbo application more so than gsr
ported and polished b16 head isnt needed as it flows great from factory
however more flow will not hurt anything as more flow will be better for turbo
IMO i would scratch the gsr camshafts and go with a full ITR valvetrain, that setup would be much better
boostedteggy
Oct 21, 2009 03:20 PM
chris61625
Oct 3, 2006 05:00 PM
eg4usdm
Feb 20, 2005 01:30 PM
EFin' Kyle
Aug 8, 2004 02:35 AM
