Are these DSS axles??
Old Dec 30, 2006 | 12:17 PM
building boost's Avatar
Default Are these DSS axles??
I got these from someone and he told me they are driveshaft shop stage 5 axles with type-r spindles (DSS hubs/arp extended studs). Can anyone tell me what they are? DSS or not? He said he bought them in 2002-2003. That rusty axle is a stock gs-r for comparison purposes. Thanks.
Old Dec 30, 2006 | 12:40 PM
A.E Motoring's Avatar
Default Re: Are these DSS axles?? (building boost)
those look stock as hell, usually the boots will be a different color when there aftermarket
Old Dec 30, 2006 | 12:47 PM
Default Re: Are these DSS axles?? (Dual Cam Racing)
they use 36mm nuts by the way.
Old Dec 30, 2006 | 12:50 PM
have u tried looking on a website? is there any part numbers on there that u can try to look up? i guess i am wrong, i keep looking at them and that stock gsr u have there, they do look like aftermarket
http://www.driveshaftshop.com/acura.ivnu
does the seller have the hubs?
Old Dec 30, 2006 | 01:04 PM
the website wont help since these were sold in 02-03. dss won't be open til tuesday so i am trying to get an answer before then cuz maybe someone can help. there aren't any part numbers on the axles, just the green stickers. the hubs are attached to the spindles already.
Old Dec 30, 2006 | 01:11 PM
B18C1CYA's Avatar
The axle in the top pic on the bottom looks to be a aftermarket unit , the spindle side looks alot bigger than the others
Old Dec 30, 2006 | 02:37 PM
gdh8su's Avatar
Default Re: Are these DSS axles?? (ixislikixi)
In the first and third pic with all three sitting there, the one in the middle makes me 100% sure that it is a DSS axle. Frank puts a stub splined insert in the passengers side axle tri-pod. Unless somebody else was doing that too!
Old Dec 30, 2006 | 02:49 PM
thanks, can anyone else confirm with a possible stage?
Old Dec 30, 2006 | 03:04 PM
gdh8su's Avatar
Default Re: (building boost)
I would say it's a stage 5. I had stage 3's and they where bigger than the 5's.
Old Dec 30, 2006 | 03:06 PM
nasteboyii's Avatar
they look like a old stage 2 dss, i used to have a set, shaft looks just alittle thicker then stock, the boots were black, and the joints were def bigger, but if it has a 36mm nut it would not be a DSS unless its a stg 3 or bigger, and then they are DEF bigger
i would guess either a outter joint was changed or maybe upgraded but deff aftermarket of some kind
hope this helps
dan
Old Dec 30, 2006 | 03:56 PM
Boostfed's Avatar
New User
Default Re: Are these DSS axles?? (nasteboyii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nasteboyii &raquo;</TD></TR><TR><TD CLASS="quote">they look like a old stage 2 dss, i used to have a set, shaft looks just alittle thicker then stock, the boots were black, and the joints were def bigger, but if it has a 36mm nut it would not be a DSS unless its a stg 3 or bigger, and then they are DEF bigger
hope this helps
dan</TD></TR></TABLE>
If they were a Stage 2 then no hub change would be needed. I was waiting for someone to mention the different boot colors , DSS didn't start doing that until late 2003 to early 2004 I believe, it could have been later than that. I have some DSS Stage 3s pucrahsed in like 2003 , since I needed one boot I have one green boot on the driver's side axle the rest are black.
These are Stage 3 or Stage 5. DSS has continually improved on their stages, almost every year they make old Stage 5s stage 3s then old Stage 6s become Stage 5s etc etc . Wish I could be more help on it though Maybe I can get a caliper on my spline and measure that for you. I will try that
Old Dec 30, 2006 | 04:06 PM
Boostfed's Avatar
New User
I did the best I could measuring the spline with my slicks still on the car, the best reading I could get and is TOTALLY off is .928" which equals 23.57mm, so it seems to be alittle off.like I said
Modified by Boostfed.com at 10:52 PM 12/30/2006
Old Dec 30, 2006 | 06:50 PM
thanks for the help. i am hoping dss will email me back on tuesday.
Old Jan 1, 2007 | 06:51 AM
b18sihatch's Avatar
kinda looks stock
civicb16alsd
Jan 19, 2008 09:19 AM
2000BoostedEX
Jul 26, 2007 11:30 AM
Flexin5
Sep 15, 2006 03:08 AM
flatty
Suspension & Brakes
Mar 30, 2006 07:48 PM
tannerLSt
Feb 22, 2006 05:28 PM
