Charge piping issue
Old Dec 27, 2006 | 02:55 PM
89efDUSTY's Avatar
Default Charge piping issue
After searching and reading alot of post...it seems that 2" CP just doesnt work well...but what if you are boosting really low and dont plan to run the car hard at all...just building the turbo for the fun and experience, will it really put alot of pressure and blow anything, excess wear, limit horsepower...i found that it will not give you the availability of power you can achieve when you reach higher RPM's...anyone know anything about this insight...thanks...ohh also will be running t25 at about 6 pounds of boost, on a D16a1 "DOHC"...with side mount intercooler...yada yada yada...thanks alot HT
Old Dec 27, 2006 | 03:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Charge piping issue (89efDUSTY)
it really comes down to how much air in terms of volume you are talking about. 2 1/4 seems to be the norm, and if i remember the hot side of the drag kits are actually 2"? and the cold side 2 1/4 but even 2 1/2 will support a good bit. just go off of your side mount dimensions. youll be fine.
Old Dec 27, 2006 | 03:03 PM
89efDUSTY's Avatar
Default Re: Charge piping issue (boostedcivicsir)
Ok...thanks yah the intercooler side mount dimensions are 2...thats why i just wants to do that instead changing size...thanks anyone have anything else i should know...
Old Dec 27, 2006 | 07:33 PM
bebfsu1's Avatar
if those are your goals then you'll be fine with 2" piping
wtsapexipowerfc
Sep 11, 2010 05:01 AM
DS002
Oct 21, 2006 09:22 PM
OH_SNAP10k_SHIFT!
Mar 18, 2006 07:04 PM
honkey2fly
May 19, 2004 12:17 PM
dingusjt
Mar 30, 2003 09:01 PM
