help!! clearance problem...do i have room to upgrade??
Old Dec 31, 2006 | 07:02 AM
gogunkergorilla's Avatar
Default help!! clearance problem...do i have room to upgrade??
my turbo is a t3/t04e 76mm 56trim .63ar. do i have room to upgrade to a gt3582r .82ar?
Old Dec 31, 2006 | 04:16 PM
Default Re: help!! clearance problem...do i have room to upgrade?? (Wicklewopper)
bump...can anyone help with this?
can anyone post the diameter of a gt35r compressor housing...thanks
Old Dec 31, 2006 | 04:37 PM
Tchleung's Avatar
Which way is your comressor housing outlet pointed? I know gonig fro my old GT30R which has an E housing, same as your turbo, then gonig to my enw GT35R which all come with the S housing, is substantially larger and will not fit with your space limitations. Although Precision does offer an E housing option for that turbo in which it will fit jsut fine.
Old Jan 1, 2007 | 08:29 AM
Default Re: (Tchleung)
oops! i just noticed the picture is upside down...the outlet points straight down.
how would running an e housing affect the lb/min on the gt35r? could it still flow 65lb/min? any less and it may be better to stay with what i have.
does anyone here have this turbo?
Old Jan 1, 2007 | 08:40 AM
Adriano's Avatar
Default Re: (Wicklewopper)
They do have the 35r with a e housing. I seen it before.
Adriano
Old Jan 1, 2007 | 09:51 AM
Tchleung's Avatar
I havent seen much info with the E housing GT35R, but as I said, Precision makes the only housing which is the E housing, otherwise from waht I've seen, they are all S.
b00stedbyFastrax
Aug 20, 2008 03:07 PM
eglslsd
Jun 14, 2007 05:36 PM
theEGkid
Sep 22, 2005 10:44 AM
booscivic
Dec 15, 2003 07:14 PM
Acura_I-RS
Apr 13, 2003 06:42 PM
