AEM 5 Bar Problems?
Old Jan 3, 2007 | 06:02 PM
building boost's Avatar
Default AEM 5 Bar Problems?
Can someone tell me how to wire an aem 5 bar? Which color on the map sensor goes to which color on the stock wiring? I searched and found that its the same as 3 bar. My 3 bar had different color wires than the 5 bar. I think I wired it up wrong because we tried starting the car and it was smoking from the exhaust manifold gasket, and spitting out fuel from that same place. Thanks.
Old Jan 3, 2007 | 06:07 PM
93supercoupe's Avatar
Default Re: AEM 5 Bar Problems? (building boost)
if u try starting the car with out re-calibrating the EMS then its going to run EXTREMELY messed up, either very rich or very lean.
Save ur motor and re-calibrate ur EMS first.The wiring may not be messed up.
Old Jan 3, 2007 | 06:12 PM
we burned a new chip for the 5 bar. its on hondata s200.
Old Jan 3, 2007 | 06:16 PM
is there some kind of calibration required to make the 5 bar work correctly? it is selected as the map sensor of choice in our hondata chip.
Old Jan 3, 2007 | 07:47 PM
anyone? hondatas website is no help.
Old Jan 3, 2007 | 08:19 PM
iBrandon's Avatar
Default Re: (building boost)
be sure ur 5 bar is not mounted to the manifold but to the fire wall...
Old Jan 3, 2007 | 08:34 PM
CustomX113's Avatar
Banned
im pretty sure you can only run the aem 5 bar on an aem ems...
Old Jan 3, 2007 | 08:36 PM
u can run 5 bar on hondata. there is a selection for it.
yes, the 5 bar is mounted to the firewall.
Old Jan 3, 2007 | 08:41 PM
T4eg's Avatar
Default Re: (95dxb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure you can only run the aem 5 bar on an aem ems... </TD></TR></TABLE>
NO, im using aem 5bar with hondata s300 no problems
Old Jan 3, 2007 | 08:42 PM
iBrandon's Avatar
my Aem 5 bar works fine on hondata...im using s300...i dont remeber the wires off hand..but i can look for ya tomarrow...
Old Jan 3, 2007 | 09:12 PM
Pro-Am 1934's Avatar
Default Re: (iBrandon)
http://forum.aempower.com/foru....html
Look at the last post on the thread. That is from the pigtail on the AEM.
Wire Sensor Code B Series
GND Green/White
MAP signal White
5V Yellow/Red
That is from the Honda side.
Jason
Old Jan 5, 2007 | 01:55 PM
CustomX113's Avatar
Banned
oh well then ****... the shop that tuned my car said that it couldnt...
bosted coupe
Dec 10, 2010 08:35 AM
CustomX113
May 5, 2009 05:37 AM
BB6-213
Apr 27, 2007 03:54 AM
fabworxs
Jul 1, 2005 04:51 AM
