In my 91 hatchback i got t3/t4 turbo what kind of cc injecters should i use
well i don't no much about my honda i just got it and win i step on the gas it almost dies on me it running 30psi my o2 is not in the down pipe and should i get a performance distributor and what kind will on D16A6 email me thanks
Mr. Badwrench
Re: In my 91 hatchback i got t3/t4 turbo what kind of cc injecters should i use (crazy_ace_civic)
ok i am making no assumptions on this one.
i will offer 2 scenerios.
1 - smart *** scenerio:
stocks are fine and all you need is a 14:1 fmu. and youll be fine. stock pump will flow plenty.
2 - non smart *** scenerio:
that much boost is too much for a stock bottom end, you need your o2 in the d.p. and the cc's depend on your power goal. also to run more than stock, you will need a chipped ecu or some form of management.
Re: In my 91 hatchback i got t3/t4 turbo what kind of cc injecters should i use (boostedcivicsir)
the bottom end is done but i don't know what they got in it if want to see pics go http://www.myspace.com/crazyhatchbackcivic and how do u put in a block guard
Mr. Badwrench
correctly should be done before it is honed, but i have talked to a few people and the general consensus is to leave it out.
what trim is the turbo and housing size?
Mr. Badwrench
wonder how hot the air coming out of it is.
put some 750's in it and go from there and get it tuned.
1988-1991 Honda/Acura - Must remove OEM resistor box and use OBD1 style injector connecting plugs rc 750cc
Mr. Badwrench
get peak and hold injectors
or remove it, jump the wores, and use saturated injectors.
your lucky you didnt throw a rod through the bottom end running a setup like that....i hate to be that guy but that car is the ugliest thing i have ever seen....
JonnyCoupe
03-22-2005 01:05 AM
