what is the best oem cam for turbo b16?
Re: what is the best oem cam for turbo b16? (ivt-t)
gsrs are generally pretty cheap to buy secondhand.....best oem cam overall goes to the ITR/CTR units. they make good, good power.
Re: what is the best oem cam for turbo b16? (ExVtec)
<FONT SIZE="6">BEST OEM CAM--- ITR </FONT>
HOWEVER. if you're setup is built, you'd find real good gains with larger all motor cams such as BLox B's .
Re: what is the best oem cam for turbo b16? (zeimbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo »</TD></TR><TR><TD CLASS="quote">turbo= teh GSR cams
all mota= itr/ctr cams</TD></TR></TABLE>
LMFAO!
LMFAO!
it's been proven that ITR/CTR cams make more power than GSR's on a turbo setup, so get your **** outta this post
Re: what is the best oem cam for turbo b16? (project dc2)
HOWEVER. if you're setup is built, you'd find real good gains with larger all motor cams such as BLox B's .[/QUOTE]
so you are saying that i can use blox b cams for a turbo set up with no problems.
im a all motor guy right now but im going turbo soon.
i
i
Re: what is the best oem cam for turbo b16? (Ruben19)
Your choice of cam should be based on your turbo setup. A turbo setup with a very small turbine/housing and small volume exhaust manifold in theory should like GSR cams far more than ITR cams. A larger turbine/housing and a long runner manifold should prefer ITR cams or even more aggressive mild all motor cams. There have been posts about this where I explain why and how this worked in a very basic way. Do some searching if you want.
Re: what is the best oem cam for turbo b16? (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip »</TD></TR><TR><TD CLASS="quote">it's been proven that ITR/CTR cams make more power than GSR's on a turbo setup, so get your **** outta this post </TD></TR></TABLE>
yea, and for the price that youd pay for itr or ctr cams, you could get a nice set of turbo aftermarket cams and since..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivt-t »</TD></TR><TR><TD CLASS="quote">i just try find the cheapest way to make more power with less money.</TD></TR></TABLE>
the gsr cams are the better route for what hes trying to do. kthxbye
Go with whatever oem cam has the highest lift. And please don't go with GSRs over a cam that has higher lift than it. Just doesn't make sense.
Re: (katoeh2o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katoeh2o »</TD></TR><TR><TD CLASS="quote">Are GSR really much better than the b16 cams. </TD></TR></TABLE> Nope!
