When is a Adjustable FPR needed??
Old Dec 31, 2006 | 04:33 PM
D-meet07's Avatar
Default When is a Adjustable FPR needed??
When is it need and at what pressure would a setup need to be at?? How do you go about calculating something like that.
Old Dec 31, 2006 | 06:25 PM
Chaos3252006's Avatar
Default Re: When is a Adjustable FPR needed?? (D-meet07)
I've always been told after 300hp or when you go with an after market pump.
Old Dec 31, 2006 | 08:11 PM
TypeSLO's Avatar
you only really need it if you start to max out your injector duty cycle. you increase the pressure a little to richen it up so you're still within the safe limits of your injectors. you don't want to exceed 90% duty cycle of the injectors. to figure out which injectors you need, you'll need to set a hp goal and search which injectors meet those numbers. each manufacturer rates their injectors by how much hp they can support. hope that helps
eg:R
Oct 23, 2009 06:23 AM
d16racer
Sep 22, 2006 07:33 PM
94_CRVtec
May 25, 2005 06:49 AM
stevieteg
Dec 1, 2004 02:09 AM
liquidxEG
Jul 18, 2004 07:20 AM
