what does it take?
Old Dec 29, 2006 | 10:39 PM
lsvtechatch92's Avatar
Default what does it take?
what does it take to run 10s in a street driven hatch (eg)
what does it take to run 9s in a track car same car ^^^
thanks
is the 10s possible with a piston rod set up 81.5mm stock sleeves...with a nice snail
Old Dec 30, 2006 | 12:29 AM
Schister66's Avatar
Man U FTW
wow.....you're going to get some fun replies on this one
Old Dec 30, 2006 | 12:47 AM
turbod da's Avatar
Default Re: what does it take? (lsvtechatch92)
its going to take $$$$, i believe u should of asked around how much hp and what h-t members recomend....there is more than just a simple answer, ............. [I sense something is going to happen here!!!!]
Old Dec 30, 2006 | 01:27 AM
PrecisionH23a's Avatar
Default Re: what does it take? (moops vs moors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moops vs moors &raquo;</TD></TR><TR><TD CLASS="quote">D15B2 and a 400mph tailwind.</TD></TR></TABLE>
lol
Power wise, you can run 9's with 600whp. Your question is kind of vague.
Try reading posts in the Drag Racing forum.
Old Dec 30, 2006 | 06:04 AM
b18sihatch's Avatar
it will take alot of money that is for sure, and great driving!
Old Dec 30, 2006 | 09:33 AM
b18sihatch's Avatar
i beg to differ, as far as hooking up goes yes it would be difficult unless you have a great clutch,traction bar,lsd setup then it would just take great driving.
as far as making the power if you have a LOT of money to invest in the best turbo and motor parts, the rest is just fine tuning everything.
but you would be looking at, at least 5k for a turbo kit that will get you relieable power and fast power.
probably 10k in sleeves,pistons,rods,rings,bearings,retainers,valv es,springs,ect
at least 15k+ to have a reliable steady 10 second motor.
then you need suspension modifications that will hold up under than much power. great slicks. ect
it takes alot more than just power to make 10s, its the details that you miss when thinking of going big!
Old Dec 30, 2006 | 09:46 AM
Default Re: what does it take? (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">i beg to differ, as far as hooking up goes yes it would be difficult unless you have a great clutch,traction bar,lsd setup then it would just take great driving.
it takes alot more than just power to make 10s, its the details that you miss when thinking of going big!</TD></TR></TABLE>
That's where I was pointing my answer towards. I figured I would let him do some searching instead. Again, with a properly dialed in suspension set-up it doesn't take a billion whp to run 9's.
Old Dec 30, 2006 | 10:51 AM
b18sihatch's Avatar
Default Re: what does it take? (PrecisionH23a)
yea definitly people have this idea you need 800 whp to hit 10s, most ppl with 350whp in a civic can hit 11s, it just takes a good ammount of money to get those kinda numbers, and relieability has to come into play also, cheap parts will yeild you cheap power resulting in **** breaking constantly.
but to understand one thing is to understand a sleeved,forged internal block alone isnt cheap, sure sleeves are 100% needed depending on your goal however if you are looking for a safe 600+whp then sleeves are your friend!!
Old Jan 4, 2007 | 01:37 PM
local tuner says he thinks he can brake into the 9s with only 400 whp
he has a lsvtec piston rod set up with 380 whp and runs 11.30s consistant on 13lbs and pump gas
Old Jan 4, 2007 | 01:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtechatch92 &raquo;</TD></TR><TR><TD CLASS="quote">local tuner says he thinks he can brake into the 9s with only 400 whp
he has a lsvtec piston rod set up with 380 whp and runs 11.30s consistant on 13lbs and pump gas</TD></TR></TABLE>
It's probably that Tony1 guy.
Seriously, what class does he plan to run that in? Not in sfwd. Get a car light enough and anything can be possible.
Old Jan 4, 2007 | 11:12 PM
no its not tony1
Old Jan 5, 2007 | 09:20 AM
b18sihatch's Avatar
I second that something gutted with no dash,heater core, lexan glass, full fiberglass front end, ect you can get a very light chassis, and with 400whp im sure you could do it, but not alot of ppl do it
Old Jan 5, 2007 | 11:15 AM
no full glas crx...only thing removed is the passenger seat and back seats and carpet...still has dash and stock body panels no fiberglass
Old Jan 6, 2007 | 09:59 AM
b18sihatch's Avatar
there are alot of guys who have high powered cars that cant even break 10 seconds flat, its not easy to do.
you have to have good traction,tires,suspension,clutch, ect
DIS-1
Jul 31, 2006 09:47 PM
EK FLY
Nov 7, 2005 03:08 PM
RevenantAE
Jan 12, 2005 12:44 PM
South Bay Surfer
Feb 24, 2004 04:08 PM
