Endyn AIR manifold problems, help!
Old Dec 29, 2006 | 08:15 AM
RotiEatter's Avatar
Ditto
Default Endyn AIR manifold problems, help!
Hey, i just finished building my motor, setup consists of stock sleeve CP 9:1 pistons, Eagle Rods, ACL bearings, etc. My fan wasnt turning on, lower radiator hose was cold, so I thought it was thermostat, bought a new one, threw it in and still same thing. So I tested the old thermostat and it was fine, the only thing I can think of that is causing my problems is the way I have the coolant lines run on my AIR manifold and stock GSR TB. So I was wondering if someone had a diagram on how they suggest to run them with the remote mount IACV. I am going to try and get pics of how I have mine, but it is gonna be hard since it is so cramped. Thanks guys!
Old Dec 29, 2006 | 08:23 AM
tony1's Avatar
Default Re: Endyn AIR manifold problems, help! (RotiEatter)
You don't have an Endyn AIR manifold problem, you have air in your cooling system...
And the remote IAC mount more or less doesn't work, it doesn't respond fast enough to make up for the lines in between. If you're going to use it, keep it as close as possible to the manifold and use at least 3/8" line between it and the manifold.
Old Dec 29, 2006 | 08:29 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: Endyn AIR manifold problems, help! (tony1)
get the air out of the system if there is any
Old Dec 29, 2006 | 08:37 AM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">You don't have an Endyn AIR manifold problem, you have air in your cooling system...
And the remote IAC mount more or less doesn't work, it doesn't respond fast enough to make up for the lines in between. If you're going to use it, keep it as close as possible to the manifold and use at least 3/8" line between it and the manifold.</TD></TR></TABLE>
Another thing, Honda redesigned the B-series thermostat. I have seen a lot of problems with aftermarket thermostats (not opening, running hot).
Old Dec 29, 2006 | 11:55 PM
WHITE DEATH's Avatar
Thats exactly what I thought air in the system, try letting the motor idle for a bit with the radiator cap off. That usualy solves the problem for me. Good luck.
Old Dec 30, 2006 | 06:05 AM
boostfeen's Avatar
Default Re: Endyn AIR manifold problems, help! (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
Another thing, Honda redesigned the B-series thermostat. I have seen a lot of problems with aftermarket thermostats (not opening, running hot). </TD></TR></TABLE>
..the Mugen low temp. thermostat seems to work nice.
CM5Falco
12
Mar 9, 2017 05:53 AM
TwoKSiR
Nov 27, 2008 05:07 PM
640K Crew
Feb 22, 2006 03:22 PM
IMPORTant Si
Nov 12, 2004 06:20 PM
Duck Sauce
Sep 27, 2001 08:10 AM
