possible compressor surge need help
Old Dec 31, 2006 | 09:34 AM
turbolsvtecalwaysbroken's Avatar
Default possible compressor surge need help
does anyone have a video of a car with a tial bov on it? i've been running this setup for quite a while and i believe the "unique" sound the guy who sold it to me speaks of is compressor surge. i've tried changing the vaccum source and running a larger diameter vaccum line but it still sounds the same any help would be appreciated
Old Dec 31, 2006 | 10:00 AM
Default Re: possible compressor surge need help (turbolsvtecalwaysbroken)
ok so i found a video clip and found out it is indeed compressor surge. does anyone know anything about the springs in them because i don't think i got more than the one spring with mine
Old Dec 31, 2006 | 03:15 PM
CustomX113's Avatar
Banned
bump for info on this
Old Dec 31, 2006 | 08:18 PM
TypeSLO's Avatar
Default Re: (95dxb18c1)
remove blow off valve and check for binding or broken seals.
Old Jan 1, 2007 | 03:29 AM
99delsol's Avatar
Same **** happened to me when i had my first turbo kit,i had two springs in my bov,and i guess it was too stiff,so i took 1 out and it solved my problem.Open it up ,and take a look inside.If infact you do have two springs,take 1 out and see what happens.
Old Jan 1, 2007 | 05:17 AM
jetlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbolsvtecalwaysbroken &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have a video of a car with a tial bov on it? i've been running this setup for quite a while and i believe the "unique" sound the guy who sold it to me speaks of is compressor surge. i've tried changing the vaccum source and running a larger diameter vaccum line but it still sounds the same any help would be appreciated</TD></TR></TABLE>
I recently installed a new tial bov, what I noticed is that if i drive at part throttle at low rpm/boost I will hear chu chu chu.... if I let off the throttle. However at higher rpms and boost I dont hear it anymore. Is this normal.
Old Jan 1, 2007 | 07:35 AM
coneheadsracing's Avatar
Default Re: possible compressor surge need help (jetlude)
I have an apexi blow off, and thats what mine does. I used to T it off another vacuum line, and it was always making the cha cha cha. I hooked it up directly to my manifold, and it was a huge difference. But if i'm light on the throttle and lift it still does the cha cha cha, but if i'm hard on it, then i get a huge woosh.
Old Jan 1, 2007 | 10:24 AM
Default Re: possible compressor surge need help (coneheadsracing)
how did you run it straight to the manifold? like an aftermarket manifold or a vaccum manifold? i've tried changing the source i ran it off of but nothing different i'm gonna try to t it off my brake booster someone told me that works well
Old Jan 1, 2007 | 02:53 PM
I made a automatic y8 manifold work with my manual setup. I ended up with a couple extra ports on the manifold. One was for the pcv, which you don't leave hooked up, and the other must have been something for an auto.
Old Jan 1, 2007 | 03:59 PM
i took it apart and the o-ring was ripped and stuck inside it so maybe that was the problem. there was only one spring in it but it was so damn stiff it wasn't even funny. i put it in a vice and heated it up for a minute so maybe that'll help
iNERtIA
Mar 22, 2007 03:24 PM
JDMB20TDA
Apr 25, 2006 05:53 AM
mike9571
Nov 28, 2005 01:12 PM
dungsta
Suspension & Brakes
May 2, 2005 10:34 AM
bretx0r
Aug 17, 2002 05:34 AM
