oil lines....
Old Jan 1, 2007 | 01:30 AM
broketuner-Sol_Si's Avatar
Default oil lines....
does anyone know where I can buy just the drain elbow that gets welded to the oil pan? I bought a use kit that came with the oil lines but no block adapter (which I have since bought) and no drain tube for the oil pan. I really don't want to have to buy a used oil pan. any help would be greatly appreciated.
Old Jan 1, 2007 | 07:30 AM
stealthmode62's Avatar
Default Re: oil lines.... (broketuner-Sol_Si)
We use a 3/8 male thread to 1/2 hose barb. Found in the homedepot plumbing section, as well as many other possible fittings.
Old Jan 1, 2007 | 01:31 PM
Default Re: oil lines.... (stealthmode62)
well that sounds more like a fitting... what I'm talking about is something similar to this:
http://www.atpturbo.com/Mercha...e=OIL
but with a 90* bend. the return line is the standard greddy line, just a piece of small radiator hose is what it looks like...there are no fittings on it.
Old Jan 1, 2007 | 01:46 PM
Old Jan 1, 2007 | 01:52 PM
that looks like it might work, butdouldn't it need to come out farther to clear the lip of the pan?
Old Jan 1, 2007 | 02:33 PM
That will be a question for you. I didn't suggest the 90 degree.
Old Jan 1, 2007 | 09:09 PM
any other suggestions? I found something on hahn racecraft website, but when I called them the message said they were closed indefinately.
Old Jan 1, 2007 | 10:01 PM
3rdgenLS's Avatar
i got a straight one off a greddy that you may have..
Old Jan 1, 2007 | 10:03 PM
Default Re: oil lines.... (3rdgenLS)
cool. can you please save it for me...I'll be getting back on the 6th or 7th. your username looks familiar...I think I bought the CTR header off of you when I was still in the NA bseries mode.
Old Jan 1, 2007 | 10:05 PM
3rdgenLS's Avatar
yes that's me, sure if your willing to pick it up.
MalcolmV8
Dec 5, 2011 05:29 PM
solo2fresh
Mar 2, 2011 04:09 PM
dan89crxsi
May 31, 2007 08:00 AM
b18_racer805
Nov 12, 2006 07:25 AM
UsaTLinh
Jun 2, 2004 10:58 PM
