backfiring in downpipe?
Old Dec 31, 2006 | 08:13 AM
w0ng_sta's Avatar
Default backfiring in downpipe?
Hey guys, i have a b16-T with a 2.5 turbo back, tuned on hondata, @ 8.5psi
Lately when im driving the car seems fine unless i accelerate past 5k.. at WOT, the car will run fine up to around 5k which is usually around 7psi at that time and the car bogs and it sounds like the car is backfiring but the noise seems to be coming from in the engine bay. IT also isnt one loud noise.. but several sequential noises almost like loud sputtering.. other than that the car's overall driveability is fine. i tried to ease the motor above 5k rpm and i did then i opened the throttle up and it happened again only this time at around 6.5k rpm.
I occasionally get a primary o2 code but ive been running without o2 sensors for some time now with no problems. With the o2 code I also sometimes get a tps code.. this i usually just clear while moving by killing the ignition then popping the clutch.. could the tps be the source of this problem?? thanks
Old Dec 31, 2006 | 08:17 AM
99B16Si's Avatar
Default Re: backfiring in downpipe? (w0ng_sta)
bad ignition components or a lousy tune
Old Dec 31, 2006 | 08:31 AM
RedEj8's Avatar
Default Re: backfiring in downpipe? (99B16Si)
Yea im gonna say something with the ignition. What plugs are you running?What are they gapped to?How old are they?How old are your plug wires?How old is your dist.cap/rotor?
Old Dec 31, 2006 | 11:32 AM
qfast817's Avatar
Default Re: backfiring in downpipe? (RedEj8)
hows the gorunds, check the omhs of the coil
Old Jan 1, 2007 | 09:04 AM
w0ng_sta's Avatar
Default Re: backfiring in downpipe? (qfast817)
i dun think its the tune cuz it was fine for a few months after the tune but lately it seems to be riching out (my o2 is temporarily out of order), i thought it might be my ignition also but would that result in poor driveability only after 5k rpm?
thanks guys
Old Jan 1, 2007 | 09:15 AM
nickromeo's Avatar
your coil is likely arcing internally.
do u often pull plug wires and not ground the wire with a spark tester or such?
cause that damages ignition coils.
Old Jan 1, 2007 | 09:44 AM
w0ng_sta's Avatar
Default Re: backfiring in downpipe? (nickromeo)
sorry im not really sure what u mean.. im actually running nology wires and they have seperate grounds on them so i think it should be alright when i pop them off right?
Old Jan 1, 2007 | 09:51 AM
RedEj8's Avatar
nology wires are garbage...My friends car wouldnt go past 4k with them..Once the ditched them and put some ngk blues it worked fine.
Old Jan 1, 2007 | 11:09 AM
w0ng_sta's Avatar
yea i know im gonna put the stock wires back on
Old Jan 1, 2007 | 11:15 AM
Haza45's Avatar
Sounds like the car may be blowing out the spark... Make sure your running BKR7E's and there gapped properly this would cause problems after 5,000 RPM. Your plugs may be fouled because your running no o2 and its running richer then usual
Old Jan 1, 2007 | 11:25 AM
w0ng_sta's Avatar
Default Re: (Haza45)
cool man yea im runnin bkr7es and i have been richin out.. thanks a lot guys ill let u know how it goes .. cept my lower control arm fell off last night and i was sitting on my front passenger tire sideways.. but once i fix that ill get bak lol
Old Jan 1, 2007 | 11:32 AM
HiProfile's Avatar
Default Re: (w0ng_sta)
If its not firing, that unburnt fuel is being put throught the turbo, and likely is being ignited by another cylinder's exhaust. You'll usually see the fireballs come out of straight-through exhausts when they let off abrubtly, and a very rich mixture is ignited in the exhaust.
93grayeg
10
Jul 30, 2011 11:35 AM
w0ng_sta
Jan 4, 2007 07:46 PM
Tchleung
May 12, 2005 10:30 AM
highperboi
Nov 12, 2004 09:19 PM
