Eagle rods, install.............
Old Dec 30, 2006 | 12:19 PM
Mugencrxsir1's Avatar
Default Eagle rods, install.............
On eagle rods for a b18, is there any indications on the rods that show which direction the rod should be installed? My hanes book does'nt say about the rods, but the stock pistions have a arrow pointing to the front side(timing belt end). By the way it's SRP pistons with eagle rods, by any chance are the rods unidirectional? I know that most rods have a certain direction they are suppose to be facing.... Thanks
Old Dec 30, 2006 | 12:33 PM
Default Re: Eagle rods, install............. (Mugencrxsir1)
bump Someone with engine building experience, especially with eagle rods
Old Dec 30, 2006 | 12:49 PM
SPOOLINmatt's Avatar
the notches for the bearings go toward the exhaust side. just like OEM
Old Dec 30, 2006 | 03:14 PM
Default Re: Eagle rods, install............. (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">the notches for the bearings go toward the exhaust side. just like OEM</TD></TR></TABLE>
Thanks, I just figured that out, I had the number 4 cyclinder backwards, and cyclinders 1-3 were correct. Thanks for the reassurance bro!
Old Dec 30, 2006 | 04:43 PM
Boostfed's Avatar
New User
Bearing tang towards the exhaust side
Old Dec 30, 2006 | 05:44 PM
DENCIO's Avatar
Default Re: (Boostfed.com)
what will happen if the tang is facing the intake side?? just curious....
Old Dec 30, 2006 | 06:01 PM
Boostfed's Avatar
New User
Default Re: (DENCIO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DENCIO &raquo;</TD></TR><TR><TD CLASS="quote">what will happen if the tang is facing the intake side?? just curious....</TD></TR></TABLE>
Try it and see then report back to us
Old Dec 30, 2006 | 08:17 PM
HiProfile's Avatar
I'd assume most of it would do with oiling. The only holes eagles have in them is by the wrist pin, but I recall seeing OEM rods with holes where the rod bearings have holes in them. No idea which motor's rods, but I'd guess it would deal with oil shooting towards the pistons and/or thrust side of the cylinder. I've also heard rods being designed slightly off center, which would take some load off the intake side, which sees the most sideloads from the piston.
Old Dec 30, 2006 | 08:41 PM
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I've also heard rods being designed slightly off center, which would take some load off the intake side, which sees the most sideloads from the piston.</TD></TR></TABLE>
How would that make any difference, if the end play is with in spec? Plus the amount of room in the end play is minimal at that. I'm just courious with what your trying to say, because I'm confused?
Old Dec 31, 2006 | 08:37 AM
DENCIO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">
Try it and see then report back to us </TD></TR></TABLE>
sorry,my block is already assembled...why don't you try it on your next build and post back here.......
Old Jan 1, 2007 | 12:04 PM
Kelly.'s Avatar
I've quit using this account
spun bearings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">Bearing tang towards the exhaust side </TD></TR></TABLE>
Old Jan 1, 2007 | 04:26 PM
DENCIO's Avatar
Default Re: (Kelly.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kelly. &raquo;</TD></TR><TR><TD CLASS="quote">
spun bearings
thanks...
h22silvia
Feb 1, 2007 04:49 PM
rohec04
Nov 29, 2006 03:06 PM
95GSRTT
Jun 28, 2004 09:34 AM
Cyber ITR
Oct 6, 2002 05:25 AM
