resistor box install. just dont get it.
Old Jan 1, 2007 | 04:36 PM
error's Avatar
Default resistor box install. just dont get it.
i know i need to wire up the injectors to the resistor box. i know that the resistor box needs to be wired up to the ECU, but to which wires? i am using the stock harness in my 96 hatch.
my second issue: after the injectors are wired to the box, how do you know which injector goes to which cylinder? does it matter?
im using dsm 450 black-tops with dsm res. box. here is a picture of my resistor box and injectors:
http://www.we-todd-did-racing....nhyud
Old Jan 1, 2007 | 04:44 PM
Timmay's Avatar
Default Re: resistor box install. just dont get it. (error)
each injector has a colored wire telling you which cyl it will be on the harness side... it wont matter which injector you use aslong as the order is right
they need to be in the right order
https://honda-tech.com/zerothread?id=517274
Old Jan 1, 2007 | 04:45 PM
error's Avatar
Default Re: resistor box install. just dont get it. (Timmay)
what is the distribution block?
so my resistor box should have 5 wires? 4 to injecors, and one to the "distribution block" ?
Old Jan 1, 2007 | 04:50 PM
ladysman's Avatar
The black probe from the voltmeter is in the distribution block
Old Jan 1, 2007 | 04:53 PM
error's Avatar
Default Re: resistor box install. just dont get it. (ladysman)
ok i get it. there should be 4 wires sending voltage from the dist. block, correct?
also, i have 2 plugs that are blocked off. one is grey and the other is blue. im assuming i go with the grey one correct? again this is in a 96 civic(obd2)
Old Jan 1, 2007 | 05:01 PM
Timmay's Avatar
yea i belive its the grey one.. then use the multi meter to find the 4 injector wires.. very easy to do
Old Jan 1, 2007 | 05:05 PM
error's Avatar
ok so far so good. now it appears that i need to wire the injectors directly to the resistor box right? this is where im confused on which wire goes to which injector.
Old Jan 1, 2007 | 05:10 PM
Timmay's Avatar
Old Jan 1, 2007 | 05:15 PM
error's Avatar
lol cool thanks. ive looked at this diagram a million times but now i get it. *derrrrrrrr*
Old Jan 2, 2007 | 07:26 AM
Schister66's Avatar
Man U FTW
good, i see someone already posted that diagram. I love that thing because i could never figure out the injector box until i saw that....
Old Jan 2, 2007 | 08:39 AM
ExVtec's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">good, i see someone already posted that diagram. I love that thing because i could never figure out the injector box until i saw that....</TD></TR></TABLE>
Best diagram to date.
Old Jan 2, 2007 | 11:11 AM
teal_dx's Avatar
Default Re: (ExVtec)
lol, I drew that a while back because I didn't get it either. glad it is helping a lot of people
Old Jan 4, 2007 | 09:54 PM
EX-T's Avatar
Default Re: (teal_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
It looks like to me that it is easier just to get some male/female bullet connectors and wire the resistor box directly to the injectors instead of trying to find and de pin the "dummy plug" on OBD2 cars right?
That pic by the way really clears it up for me as well!
Old Jan 10, 2007 | 08:57 AM
ExVtec's Avatar
Default Re: (EX-T)
Soldering is best....and doesn't take much longer...
food
Dec 29, 2007 06:49 PM
z6
Jun 19, 2004 06:37 PM
JBk24crx
Oct 24, 2003 12:43 AM
2k1_ITR_0736
Jul 1, 2003 02:45 AM
