Winter boost creep problem??
Old Dec 29, 2006 | 08:35 AM
purpleh22's Avatar
Default Winter boost creep problem??
I'm having problems with boost creep. H22, GT30 w .82ar, Tial 46, 3"ex. system with test pipe and dump tube. The Tial has a 11.5 lb spring.
I have a boost guage and a Blitz sbc electronic controller with digital readout. With the control turned down to where it doesn't affect the boost (running off the spring) it boosts to 15 - 15.3 on the gauges. A tuner said that some of it is the gauges and that their mustang dyno unit usually reads a lb. or two less than gauges in the vehicles they run on their dyno.
A counter person said that I'd see more boost creep in the winter because the air is more dense. It's 32 to 45 degrees here. I would think that pressure is pressure and that the WG spring would activate at the 11.5 lb. level whether it was colder or not. Maybe if I had boost creep anyway, more dense air might make it worse??
Anyone with comments or experience on this?
Old Dec 29, 2006 | 08:38 AM
willyboyK20's Avatar
Default Re: Winter boost creep problem?? (purpleh22)
what kind of manifold are you running?
Old Dec 29, 2006 | 08:51 AM
purpleh22's Avatar
Default Re: Winter boost creep problem?? (willyboyK20)
GE intake and Revhard ex.
Earlier after checking the system for leaks, the tuner checked with precision, they changed the sc61 out for a GT30. It was better but could have been leakage @ fittings. I should check the intercooler under pressure next.
ralph11sec
Feb 25, 2009 10:27 AM
mrbsponge
May 30, 2006 06:00 AM
siis2fast
Aug 28, 2005 08:21 PM
SPOOLINmatt
Apr 16, 2005 10:13 PM
Quetzolcotl
May 24, 2002 01:30 AM
