engine building
Old Jan 1, 2007 | 11:05 AM
supraccordlx's Avatar
Default engine building
I've been thinking about it for awhile and want to build a good reliable motor to run 12's in a 1/4. I don't want to work on it constantly just to keep it there.
It will be going in a 93 civic coupe, and wanting to go bseries.
My questions are, what bseries should I use? and what do I need to upgrade on it.
also what turbo setup should I get? thinking about boosting 10 to 12 psi.
has anyone built this motor yet?? or is it possible? As soon as I sell one of my car I am going to build this. My price range is going to be around 3k is this even possible????
please give me some direction on what you all have done and what works, and I will continue searching on honda-tech.
Old Jan 1, 2007 | 11:09 AM
Topdawgg's Avatar
ive seen a 96 sedan run high 12s with a 100 shot on a GSR motor...
you wont be able to get a swap and turbo it for that much i wouldnt think... unless you shop around...
you could boost an LS motor, get the swap for pretty cheap and then a decent turbo setup...
Old Jan 1, 2007 | 11:14 AM
Default Re: (Topdawgg)
I plan on looking around for the best deals, I don't want to spend more then 3k unless I have too.
Old Jan 1, 2007 | 11:26 AM
Schister66's Avatar
Man U FTW
$3k for a B built B swap and a turbo setup......keep dreaming. Also, i'm really shocked that people have been rather nice so far. With an open ended question like that, you usually dont fare too well. I know you must have a lot of questions, but you also do need to do your own research. There is plenty of info available if you chose to look for it...
Old Jan 1, 2007 | 11:27 AM
HiProfile's Avatar
Default Re: (supraccordlx)
Whats included in that $3k? Motor only, or motor parts + motor + turbo?
If you want it fast and reliable, I'll assume thats motor build only. $200 LS shortblock, $500 vtec head, $900 bearings/rods/pistons, $200 seals/hg/etc, $300 water/oil pumps, plugs/wires/dizzy/etc $400. So $3k would do it.
Otherwise a low-milage JDM B16, a 57trim, 2.5/3bar map sensor, turbo parts, and cromepro could just barely fit under the $3k, yet still get you into 12's.
Old Jan 1, 2007 | 11:30 AM
Schister66's Avatar
Man U FTW
i really struggle to think he can make a good setup w/ a built engine for less than $3k. The small things are going to catch up with you....like and exhaust and tuning. On my setup that's nearly $800 alone. Not to mention a clutch ($400) and all of the other parts you're going to need......i'm not saying it cant be done, but i wouldn't attempt it for that little money....
Old Jan 1, 2007 | 11:33 AM
Default Re: (Schister66)
maybe I should clear things up I 3k on the motor, tranny, and misc stuff...
and I have been researching I posted this topic to see if any of you all have built what I am wanting to do is all..
Old Jan 1, 2007 | 11:34 AM
Topdawgg's Avatar
just motor and tranny??
LS block, pistons rods... head studs..
b16 head, and an LS tranny...
done and done
Old Jan 1, 2007 | 11:40 AM
Schister66's Avatar
Man U FTW
If you're planning to spend $3k on ONLY the built engine and swap, then you're fine. When i initially read it, i took that to mean you're building the engine and finding an entire turbo setup for less than $3k....which i see as a difficult thing to accomplish.
Engine build for $3k shouldn't be a problem....LS/VTEC ftw on that one
Old Jan 1, 2007 | 11:43 AM
would it be better to go all gsr? or ls/vtec I just don't want oil leaks it gets on my nerves and was reading a write up about it here.
great write up by the way.
https://honda-tech.com/zerothread/1676914
Old Jan 1, 2007 | 11:45 AM
Schister66's Avatar
Man U FTW
There are a ton of people using LS/VTECs with no problems on this site. There are probably more of them than there are straight GSR engines here. Personally i wouldn't worry about using an LS/VTEC if you do it correctly. I'm planning to build one this summer and through next winter for spring 08......god that's a long time still....
Old Jan 1, 2007 | 11:51 AM
which bseries block is better?
and what head are you using?..
Old Jan 1, 2007 | 11:54 AM
Schister66's Avatar
Man U FTW
just based on availability and price, i'm going with either a B18A or B18B....just depending on what is around when i decide to buy. Also, i'm using a GSR head....
Old Jan 1, 2007 | 12:00 PM
alright thanks.. I'll continue searching.
if anyone has a setup post it up for me. thanks
Old Jan 1, 2007 | 12:22 PM
Topdawgg's Avatar
yea.. just find a decent b18a/b block in good shape and do that...
GSR and Type R blocks are nice too, but usually alot more due to the solid girdle and just being a better all around block
Old Jan 1, 2007 | 01:19 PM
thanks for the info.
Old Jan 1, 2007 | 01:28 PM
. a d a m's Avatar
rods/pistons d-series ftw
It could EASILY be done for 3k.
Old Jan 1, 2007 | 01:40 PM
Default Re: (. a d a m)
im not a dseries man, I have a 1.6 in my civic for a gas saver, it can barely take off w/ the ac on!! haha
404_FSP
Jan 17, 2018 10:55 AM
bigballing222
53
Mar 17, 2011 02:43 PM
JSPECDC294
Jan 22, 2007 01:32 PM
gsrdelslo
Jan 29, 2006 06:17 PM
CTR-GSR
Sep 16, 2005 05:48 PM
