map sensor
Old Dec 26, 2006 | 04:43 PM
beaterman's Avatar
Default map sensor
so im putting on my turbo kit and of course i come to a snag when i get to the end. im using a missing link bypass for my map sensor. but my map sensor plug has no screws to undo. is this the map sensor or am i looking at something else. pics below.
Old Dec 26, 2006 | 04:48 PM
Synapse Motorsport's Avatar
Default Re: map sensor (beaterman)
Thats the TPS Sensor
Old Dec 26, 2006 | 04:49 PM
Markb16a's Avatar
I think that is the tps sensor?
Old Dec 26, 2006 | 04:52 PM
Default Re: (Markb16a)
You should really think about ditching the fmu and missing-link. Get some injectors, an ems, and a tune, your car will love you for it
Old Dec 26, 2006 | 04:58 PM
JDM_EM1's Avatar
Default Re: (Synapse Motorsport)
^^^^ deff what he said....
Old Dec 26, 2006 | 05:03 PM
beaterman's Avatar
Default Re: (JDM_EM1)
i would really like to get all those things but i dont have the money right now. i just want to get the car running. so where is my map sensor? can anyone show me. thanks
Old Dec 26, 2006 | 05:10 PM
batboyvaj's Avatar
Default Re: (beaterman)
you can pick up a set of dsm injectors for like 30 bucks nowadays.
Old Dec 26, 2006 | 05:11 PM
batboyvaj's Avatar
Default Re: (batboyvaj)
your map is probably on the other end of the vac. tube in the pic (on top of the throttle body)
Old Dec 26, 2006 | 05:58 PM
93turbo16's Avatar
What chassis is this motor in and what TB are you using?
Old Dec 26, 2006 | 06:01 PM
Tchleung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterman &raquo;</TD></TR><TR><TD CLASS="quote"> i dont have the money right now. i just want to get the car running</TD></TR></TABLE>
No offence, but you cannot embark on turboeing a car if your finances are tight... Otherwise you pay for it with a broken motor.
And looking at that TB, the map sensor is most likely firewall mounted. Should be taht vacuum line comngo off the TB just infront of taht open nipple that is sposed to goto the charcoal cansiter
Old Dec 26, 2006 | 06:03 PM
beaterman's Avatar
Default Re: (93turbo16)
the head is from a 94 gsr but i believe the throttle body is from a 93 or older ls integra. does anyone know if i get a new throttle body from a 94 and up integra if i can use the same wiring harness for the map sensor that i have now?
Old Dec 26, 2006 | 06:08 PM
93turbo16's Avatar
You have two options as I see it.
1) get a firewall mounted Map sensor from an older civic and run it to that vacuum line on the top of the TB.
2) Get a Newer Teg throttle body and it will have it mounted on the top.
And as everyone else stated please look into better fuel management. If you have any question in that category you can shoot me a PM. That is something you deffinitley don't want to over look.
reddysol
Sep 8, 2007 10:57 AM
methos713
Jun 11, 2007 12:43 PM
turbojdm521
Jun 12, 2003 11:29 AM
