Turbo ????
Old Dec 30, 2006 | 03:32 PM
EG_LS's Avatar
Default Turbo ????
I have a 94 eg with a ls swap... Im planning on gettin a turbo kit in a couple of days, but first i wanted to know how hard its going to be to install it, and what problems will i run into??(have no a/c so have space to work wit) Thanks for all help
Old Dec 30, 2006 | 04:04 PM
KeyserSoze's Avatar
Default Re: Turbo ???? (EG_LS)
First check here---> https://honda-tech.com/zerothread/1024174
Then if you don't find an adequate answer, post up another thread with a specific question and someone will be more than happy to answer you.
If I had to rate the difficulty on a scale of 1-10 (1 = easy as picking your nose, 10 = A Jean Claude Van Damm gay in the air split kick [impossible for a straight guy to perform.....]). I would say 3-5 (with no complications) or 4-9 (with complications; dp doesnt fit, block needs to be shaved, manifold doesn't fit, need to change ic piping, etc, etc, etc........). These number also depend highly upon your own mechanical skill. GL.
nokehockey20
Jun 13, 2016 12:54 AM
hebrewhammer
May 21, 2009 05:11 PM
BOOSTEDgs-R
Feb 17, 2008 04:00 PM
903
Jun 23, 2006 09:46 AM
cL2.2
Sep 7, 2005 10:03 AM
