Blown Engine
Old Dec 27, 2006 | 01:21 PM
srg's Avatar
srg
Default Blown Engine
Hello,
I heard some ticking noise from engine 1 week ago.
And today when I WOT and hit 2nd gear my engine blown..
here is pic:
My engine was D16Z6
What block can I use to replace this and use D16z6 head on it..?
BTW, I'd like to replace pistons and rods.. what do you recommend?
Sorry for my bad english
Old Dec 27, 2006 | 01:31 PM
RedEj8's Avatar
Default Re: Blown Engine (srg)
Ouch..First you need to find out if the head is even salvagable.
Old Dec 27, 2006 | 01:44 PM
blwn95civic's Avatar
Default Re: Blown Engine (RedEj8)
dang!!! thats one of the worst block break thru's ive seen in awhile... do you know what caused the problem? miles on motor?
Old Dec 27, 2006 | 01:45 PM
srg's Avatar
srg
Default Re: Blown Engine (trav95civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trav95civic &raquo;</TD></TR><TR><TD CLASS="quote">do you know what caused the problem? miles on motor?</TD></TR></TABLE>
BAD TUNE!!!
Old Dec 27, 2006 | 02:07 PM
HiProfile's Avatar
That looks exactly like the motor the user 'k_motor' sold me. From what I've gathered, it was in his brother's car, boosted & not treated well (*iron* studs used to post the sleeves), and the knocking lasted a week till it tossed a rod while I was cruising at 60mph. Totoally stock ecu, intake, head - I just thought the rockers were causing the noise. The motor that was in this car when I bought it also had a hole in it, cyl #2, D16z6. That hole was from the previous owner's BF reving it to 9k, but it also had some old skool chip in it (which I threw out) that had seen (caused) 2 other motors to blow.
My point is its usually a bad tune that beats on the bearings due to detonation. It could be from previous abuse (like my 'k_motor' block), or the existing tune (like the block the 'k_motor' one replaced). Unless you tune the new motor with more timing retard or get custom pistons that drop compression to 8:1, it probably won't survive either.
Old Dec 27, 2006 | 02:19 PM
mtber's Avatar
Default Re: Blown Engine (HiProfile)
Take the motor apart & find out.
Your problem could be anything from rod bolt failure to who knows what....
Old Dec 27, 2006 | 02:34 PM
zccr-xsi's Avatar
Default Re: Blown Engine (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Take the motor apart & find out.....</TD></TR></TABLE>
Old Dec 27, 2006 | 08:48 PM
Chaos3252006's Avatar
if you can salvage the head, then toss it onto a d15b7 block and be down with it.
Michaud85
15
Nov 29, 2014 01:42 PM
Red_Si
Oct 29, 2006 05:57 PM
EGHatch94
Jan 19, 2006 11:12 AM
wing
Dec 24, 2004 05:09 AM
2camsaam
Nov 18, 2002 08:18 PM
