Replacement trunk steel pan for rusted out one?
Does anyone make an aftermarket bolt in replacement steel pan for the trunk? All these rusted out trunk pans under the spare must mean someone makes a bolt in replacement.
Re: Replacement trunk steel pan for rusted out one?
I understand the original pan is welded in. I was asking if anyone makes an aftermarket replacement to install vice smearing bondo or fiberglas on it for a temp fix.
You can't install a new spare tire well by adhering it to the chassis with Bondo...if you aren't able to weld in a new one, then take it to someone who can. As far as purchasing one, Honda may still sell them so check on oemacuraparts.com. if not, then source one from a salvage yard that's in a state like California, New Mexico, etc
