1995 Integra GSR Sedan
Picked this car up a couple years ago but just now getting around to posting about it. I am the 3rd owner, the 2nd owner bought it, had plans but had too many cars so sold it to me after about 8mos of ownership. The original owner had the car for 20+ years and had a box full of maintenance records as well as the window sticker which I inherited when I bought this car. The interior is clean with no wear. It still has the tape player and even the antenna still goes up and down. The rubber window trim is still black and tacky. When I got it, i replaced the shocks with bilstein HDs using the stock springs. The original exhaust was not good anymore, so I replaced with a period correct Tanabe G Medallion. Most of the suspension bushings were fine, and all that needed replaced was the rear trailing arms from Hardrace. I also replaced the engine mounts with a Hardrace hardened rubber set. That's all I could think of for now. As for plans, I don't have much. I struggle with lowering it or not because I like how this is a rare car and am more about keeping it close to original as possible. Here's some pics.
Re: 1995 Integra GSR Sedan
Nice find!
It even has a ITR strut bar!!!!!!
You could remove them and have them flow tested and cleaned! lots of places offer this for injectors.
id recommend getting some ITR springs to replace the stock ones, it'll lower it about an inch perfect ride height for looks and function. it is what i have on my sedan. also an icebox and or a drop in ct engineering filter.
I’ve been looking for just the springs but no luck. I removed the resonator box and kept the tube that should connect to it. Its like a CAI but using all stock components, basically like a ct engineering design but free.
Getting the drop in filter will definitely help performance, more free flowing and has the velocity stack in the elbow.
Beautiful car
Had a quick question, would you be able to take a picture of the rear deck behind the rear passenger seat? There are 3 little hook there (child seat I think)< I want to see if comparison to mine, if my covers are missing. Thank you
I took it up
angeles crest and down the 39 to Azusa
I really wanted Bilstein, as that is what I have on other cars, but ended up with the koni yellow
I have some super sticky advan rubber on there
It’s been awhile. Feb 2021 I had the motor completely rebuilt by Importlife Performance in Hawaiian Gardens,CA. It was a 0-mile rebuild that replaced everything. I have ~8k miles on it as of 27 Feb 2022. Last month (Jan 2022), i had the front bumper and lip repainted because the clear coat was peeling. I also ended up painting the rocker panels and sideviews to make everything look fresh. I also got the headlights recleared and wheels polished and coated. So now it all looks closer to that showroom stock look im going for.
Next thing up is to replace all the suspension bushings with tje hardrace rubber bushings for that fully refreshed suspension feel.
Here are some pics!
Here are some pics!
