99 Integra LS noise help IMPORTANT
I keep hearing this god awful whine/hum from the drivers side wheel. It happens while driving and when i push down on the area. What is it? HELP!?
Maybe a Cv boot? Something worse? Help
heres a video of the noise:
Re: 99 Integra LS noise help IMPORTANT
Bruh what??? Sounds like a violin under your quarter panel. My shocks/struts are going bad and they make loud scratchy noses when I hit bumps, maybe it's your suspension. How hard are you pressing down? Didn't seem too hard on the video. That's where I'd start looking, with the springs on your shocks. You could quickly tell by lifting that tire off the ground and doing the same pressing method. If that tire's off the ground and it still makes that noise then it's not anything to do with your suspension/wheel
It's either your springs/shocks or something in your suspension just broke. If it's the later, it should be very apparent. If you just jack it up and pull the wheel off, you should easily be able to see what's broken or very worn.
