2000 Acura Integra gs-r turbo running obd1 needs smog help!!!
My 2000 Acura Integra gs-r turbo (built motor) running obd1 without cats needs smog help.... I’m in Bay Areaa, CA. If you guys can help me with smog, please let me know. Thanks.
Re: 2000 Acura Integra gs-r turbo running obd1 needs smog help!!!
Maybe someone will PM you with a shop that will do it, as is. I used to just take the whole turbo setup out every 2 years to smog. You can't pass smog in a 2000 with an OBD1 ECU. You also need a cat.
i tried to put the ob2 p72 ECU and the car wouldn’t start! The OBD1 ecu is chipped and had a tune on it. Probably the reason car can’t start because ID1000cc injectors and Walbro 255 fuel pump??? Is there a way the car can start with obd2 P72 ecu??
no the best to post on a public forum how to get a shady smog. another reason i opted to make sure i went to the ref myself and certify my gsr swap so i didn’t have to worry about a shady smog.
cali_don760
03-10-2011 08:22 AM
