Help deciding between motor mounts
So, I've gotten fed up with my polyurethane mounts I installed when I did my engine swap 1.5 years ago and have decided to change them out. The issue is, I've just moved across the country to California and money is super tight right now. Optimally, I'd like to buy a new set of OEM mounts but that's out of the picture for the time being. Right now I'm weighing between two options: cheap brand new mount set from rockauto, Amazon, etc for $50-$70, or used OEM mounts. Which do you guys think would be a better option assuming the used OEM mounts weren't too high mileage?
Re: Help deciding between motor mounts
I don't know if the cheap mounts from Rockauto are the same as ebay OEM replacement mounts, but if they are, then they will be trash. i tried the super cheap ebay mounts for a car that i was going to sell and the holes wouldn't even line up on the trans mount. I would have had to elongate the hole by 3-5mm.
I bought a cheap set from ebay, came as a kit with all five mounts, fitment was good and they work fine, low cost. I ended up skipping the side mount on the driver side by the timing belt mount as the vibrations increased more than I wanted, I put the oem side mount back in and everything was good again, the oem side mount is pretty good and rarely fails, the other mounts are the ones that need replacement more often than not. I hate any car with vibrations caused by hard mounts.
I would not hesitate to buy from RockAuto if money is tight. I've ordered Moog bushings from them before and received OEM bushings instead.
