Integra B20 (high comp) swapped
Is there any way I can get ps & ac? Bought the car with swap and can't find anything on this subject for this specific swap. Just curious if it's possible, as well as what I'd need?
Re: Integra B20 (high comp) swapped
The PS pump and AC compressor bolt up to a B20 the same as they do with a B18, the blocks are identical externally. The only difference would be in the belts if the B20 still has the B20 crank pulley, the B20 crank pulley is sized differently so you'll need different belts.
crxcess
08-24-2002 02:38 PM
