98 acura integra problems
Old 05-19-2019, 05:59 AM
Henry Tyre's Avatar
Default 98 acura integra problems
Replaced motor in 98 integra with b18b1 in it. Car starts idles fine. I can go in reverse and back up but as soon as I put into gear and hit around 2,000 rpms it bugs and then dies. Replaced fuel filter, spark plugs, cap and rotor, tps. I'm lost at this point. Any help would be appreciated
Old 05-19-2019, 09:04 AM
jdmark1's Avatar
Default Re: 98 acura integra problems
Did you check the timing belt and mechanical timing? If it was a JDM import motor, a lot of them are still on their original timing belt and need to be changed due to age. Also, check your ignition timing if you've down work on the distributor. How's your idle? I would also try to get a fuel pressure reading to make sure you're getting enough fuel. More info would help to, like what year your car car is and what OBD your motor swap is
Old 05-19-2019, 01:24 PM
Henry Tyre's Avatar
The car idles fine (800 rpms) I'll try to get a fuel pressure reading tomorrow. If it helps my car is a 98 and the motor I got came out of a 96.
jpnolan
06-10-2013 04:29 PM
pimpwagon
11-12-2010 08:41 AM
boarding2008
01-25-2009 02:06 PM
Turbo_y8
05-24-2005 07:06 AM
4drDA
01-26-2005 01:17 PM
Quick Reply: 98 acura integra problems
