Rod length
Old Nov 13, 2019 | 04:39 PM
SlowC1vtec's Avatar
Default Lsvtec Rod length
B18b1 block w/ b1 crank. C1 head. Getting low comp pistons but i dont know if I need to get Different length rods to match the gsr head.
Old Nov 14, 2019 | 01:12 AM
K20.ek's Avatar
Default Re: Rod length
You got to match the rods and crank together ls rods to ls crank or gsr rods to gsr crank no mix match.
Old Nov 14, 2019 | 06:24 AM
SlowC1vtec's Avatar
i know the gsr rod lengths are at 5.430 and b1 rods are at 5.394. Would it be ok to run 5.394 rods with a GSR head?
Old Nov 14, 2019 | 05:49 PM
K20.ek's Avatar
You ll be fine with that setup depending what pistons you use.
I ran a ls crank, ls rods with Usdm type r pistons in a gsr block with gsr head and had no clearance issue at all. I would put my compression at around 11.2-11.5cp with the head milling too.
any higher than that I wouldn’t risk unless you building a track car and using meth kit.
fv8s
17
Jul 9, 2010 12:25 PM
dirtyharryhatch
10
Jul 21, 2009 02:43 PM
Mfoehrkolb
Nov 21, 2007 05:37 PM
TurboEH2
Apr 2, 2005 11:03 AM
advanracing62
Oct 11, 2003 09:57 PM
